I have had coolant poor down from behind the engine somewhere and passing down onto the ground generally when the car gets to temperature. . Rather than replace heater hoses which i think is the issue. I want to delete the heater all together. Is it a big job?
Just join the two pipes going through the firewall into the heater core on the engine side. Pull of a hose and get something like a brass plumbing pipe from bunnings that matches perfectly and cut to size and clamp the two hoses that would otherwise run into the heater core together. Will solve your leaking issue if your heater core is in fact the problem. Getting the heater core out of the Dash is a much bigger job from the inside.
Edited by sonicz
I just want to delete the heater hoping that is the problem.. what else could it be? Btw I have checked inside the car drivers side and passenger no signs of coolant leaking inside.
Edited by boobeedoobee
If it's not leaking inside then the leak is in the engine bay somewhere. Try as sonic and Ben have already stated and if it's still leaking you will have to find the leak. No other way around it.
Generic 1m lengths of oil and water hose isn't expensive, and by the sounds of it they will need replacing regardless.
If it is leaking behind the engine then you really have NO CHOICE but to find the hose back there that has a hole in it and replace it. And of course, because all the other hoses back there are old and crusty, you should do them too.
Deleting the heater would be a counterproductive effort that would take the same amount of effort as just fixing the problem.
  • Like 1
by the sounds of it you have a leaking hose which may or may not be a heater hose, I suggest finding which hose it is and replacing it.
If it was the heater core that was leaking the water would be inside the cabin
Ok thanks ill replace the leaking hose which your right might night be a heater hose. Just wondering though before I go and buy a heater hose kit..as I will be deleting the heater will this eliminate the need to replace the heater hoses?
Ben is there a way if getting around that after deleting the heater?
There are options, electric heater fan things for that very reason. I don't think j they actually work particularly well, but they satisfy the law.
I feel like in the time you've spent asking for ways aroung the way around, you could have just organised parts to fix the problem
I changed all my heater hoses with a Greddy copy plenum a few weeks back. Was a pain in the ass, but only took about 2 hours to replace all 4 heater hoses. Stop being lazy and fix the car rather than putting everything in the too hard basket.
Ok thanks heater delete it is.. save future leakage problems. Less hoses less trouble. I've never actually used the heater and never will. Wasn't trying to be lasy. Just needed to know what parts to organise depending on which way i went with it. Air con will go also
Google heater hose diagram rb26 and then decide on what you would like to do. Whether that may be replacing all hoses (I would do this) or cutting and blocking the heater hoses. It's one of the first things kids learn while driving around in beaters. Heat and plastic doesn't mix well after 10+ years.
    • Yeap, not as doorty as ITB's, but alot more doorty than before, induction sound great when I'm up it 馃
    • Any difference in induction noise?
    • I think you know exactly who I mean.
    • If I got a dollar for every flipped commuter missile I've driven past I'd have two dollars   Some people get into wild adventures on the road and I doubt it's gender or ethnicity specific. I'm just glad I don't usually drive during peak times.
    • Just got the car back and gave it a good run back home Power wise, whilst it only made a extra 5 killerwasps up top at 7200 rpm, it made more power everywhere from 2500 rpm and kept pulling much harder all the way, to the point of me relearning when to shift so I don't hit the 7200 limiter, with the old intake it seemed to take alot more time to rev out, and, throttle response is also much improved  As I didn't want to remove the bumper every time I serviced the air filter (basically every aftermarket and fabricated CAI has the filter behind the bumper) it currently has a hektic exposed pod in the engine bay sucking in hot air, this will be rectified shortly after some some of my CAD (cardboard assisted design) for a alloy heat shield feed by the OEM intake tube behind the bumper, this will cop some wrinkle black paint, as well as the intake pipe for that totally OEM look... The only fly in the ointment was that the OEM "strut" brace doesn't fit over the rear runner of the new intake with the 2.5 engine is in the engine bay, as the 2.5 raises the engine up by 20mm, it's not a war stopper, and I didn't notice any difference without it in some twisties, but....... MX5 Mania is bringing in some GWR "fancy pants" braces that apparently do fit, if it bolts up I'll grab it, it is also stiffer than the OEM one, which is a bonus All in all I'm happy with the outcome      Fancy pants "strut" brace that gives the required clearance      This is where the clearance issue was, the GWR extends out past this
