up for sale is my R33 series 2 head, the tomie cams are 256 8.5lift and less than 5000km's as it was a weekend car,
The head is in perfect working order, before cams had 175 on comp test so the valves are sealing well.
Has been off the car for 6months and ive wrapped it up , selling because id like a neo head to go with RB30...
Without cas im looking for $550 , with stock cams this head is good for reselling if you just want the cams so its a fair price..
https://www.sau.com.au/forums/topic/455640-rb25det-r33-head-with-tomei-cams/
Forgot to mention the cam key snapped off when I had CAS problem, it doesn't effect anything, its just a locator for the CAS, runs perfect , have dyno sheets and video to prove it :yes:
this head is seriously in mint condition, cams have bathed in Mobil 1 and only done a few thousand km's, even the rocker covers are clean, check it out ...
You don't need to mess with this head, its mint, bolt it down or swap the cams over.. its quality..
Cams only $450 firm
whole head, cams and cas $600
Cas only $200
Edited by AngryRB
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
