Precision 6466 (GEN2 CEA) T4 twin scroll 0.84 A/R - New/Unused
$2,200 — Eastern suburbs - Doncaster area
Hi guys, I have a turbo up for sale.
950hp rated although these are known to go way beyond that.
It's been on my engine for fitment testing purposes only, never run.
I am selling due to wanting to upgrade to a larger/different turbo.
Right now these are about AUD$2500 new + shipping from the US.
Also includes the parts you see in the photos - oil drain flange, 3-5/8" V-band fitting for welding to your dump pipe, and V-band clamp.
There is an insignificant amount of rust on and around the flange area that can be removed easily.
Any questions, please feel free to PM me or comment here.
I will accept reasonable offers if there is minimal interest in the places where I have this advertised.
Cheers.
Matt - makro86@gmail.com - 03 9450 2246
  • 9 months later...
    • you can enter your VIN (the original, japanese one) here to find the correct part#: https://www.amayama.com/en/genuine-catalogs/nissan however, after all this time it is more likely to be a wiring issue than the sender
    • no, it was the same here, just flurries but no need to get the toboggan out....but it is exactly the sort of days where its good to have some inside jobs on the list. Speaking of which the fuga is driving properly after 2 1/2 years.....but that is a whole other thread
    • And yes, put in the restrictor while you are there; a standard engine is fine with a little less oil and you are less likely to run out of oil if you have sustained high revs for any reason eg visit a track one day. How did you clean the cooling system
    • I didn't think about how a circle works before, dumb.  Before, I had .9mm restrictor bolts but I can't use these cause they were shorter aluminium bolts that just tear off their threads when tightening since the OEM lines are thicker than the shitty braided one that was installed previously. Now I use longer 1mm stainless steel restrictor bolts. I think the difference will not affect the health of the turbos, but I guess I'll have to drill out the main feed bolt as I agree multiple restrictions sound dodgy. The one that was installed with the braided line was just too short, but completely without a restrictive hole.
