Hi all,
I have a few bitz from a Rb25det race engine that i never completed & it has since
been laying around my shed for a while.
I need to move them on.
List is as follows,
1- Rb25det Stage 2 Race head.
I have had this built by a professional shop and it is still brand new wrapped up in plastic.
Head is off a series 2 R33 Gts-t & suits any Rb25det bottom end.
Chemical clean
Preasure & crack tested
K-line guides,multi angle valve job
Replaced super tech seals
High lift spring & retainer kit with 9.5mm lift caability
260cfm Race port for maximium flow.
Included in the price is a pair of Tomei Poncams.
Inlet is 256mm with 8.5mm lift
Exhaust is 264mm with 8.5mm lift
Also included in the packege is an adjustable Hks cam gear.
With this Poncam set up you can still retain the factory VCT which is worth using as it will help with boost coming on around 500rpm earlier.The Poncams will give you greater low to mid range torque.
This head is brand new,the Tomei cams and Hks cam gear have done around 1,200klms in a previous set up,& are in as new condition.
Complete head set up with Cams & adj cam gear $2600
2-Rb25det Stroker bottom end 2.7l.
*Components have been in workshop sitting around & has some surface rust on Block,
small amount on crank and some surface rust on the rods (as pictured)
The block is Rb25det that has been mechined to 87mm
The block was originally mechined at Jack bros Racing in Slacks creek along with the Rb26 Gtr crank & girdle.
Pistons are JE from memory..87mm. New Total rings were fitted.
Rods are Crower.
After a small engine falure on the dyno (bearings) the bottom end was then stripped
down and re machined by JHH Racing where it has since been sitting around in my shed in its current unassembled state.
Odviously you will need to freshen up the bits again.
Whole bottom end,Block,pistons,rods,Gtr crank & matching Gurdle $650
3-Rb25det cranks & girdle.These were extracted from 2 good engines but didnt end up
getting used.They will need a freshen up as have some surface rust on them
$150 each
4- This set up came out of a running Rb25det
R33 Gtr injectors in Rb25det fuel rail with harness
R33 Gtr injector resistor pack
Z32 airflow meter
Dont want to seperate at this stage
Complete upgrade kit $350
5-Ross Tuffbond metal jacket harmonic balancer Rb25det.Part number 306201.
Rated to 1500hp
Has done around 1,200klms and is still like new.I paid $750 for it.
Sell $300
6-Nismo Rb25det Engine mounts (left & right). Again done around 1,200klms & comes
with the factory alloy bracks,Mounts are like new $230 pair
7-R33 Gts-t dash cluster. Showing 82,000klms $120
8-Rb25det starter motor $60
9-Rb25 valley cover $30
Rb25 rocker cover (oil cap side) powder coated blk $30
Rb25 timing cover $10
Im located on Brisbane southside.
Pick up welcome
For interstate buyers i can post or help with organising a courier for you at your
cost.
Please give me a call to make a time to view or if you have any questions.
0424-380-848
Cheers!
  • Like 1
  • 3 weeks later...
  • 1 month later...
  • 5 weeks later...
  • 3 months later...
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
