Just got my nismo side skirts in and I picked up new mounting hardware from nissan. I was hoping someone can give me some details about the mounting process, I assume all my lower mounting holes are present but what about the upper portion of the rear pieces?
Cheers
https://www.sau.com.au/forums/topic/455670-32-nismo-skirt-mounting/
just uses double sided tape afaik
how much was the mounting hardware? what did it consist of?
would love to take mine apart clean and re fit
Just double sided tape won't do it. Maybe for the guard section, in front of the rear wheel. I mounted mine a few months ago. (3m tape). If you don't have the clips then sikaflex may be a option.
Best option is getting the clips and doing it properly.
Good info - slowridn73. They're a pain to track down part numbers etc
Use 3M PT1100 double sided tape. It's made for that kind of stuff. The Original side spats fits perfectly to the chassic, you wont get any problems with this tape.
Using it myself for two years now. Best tape for exterieur parts like side skirts or spats. But let it harden for a few hours after you applied it, best with a slight pressure against the spats.
  • Like 1
Double sided tape works best and its the way it's supposed to be done, don't f**k about with any type of glue you will regret it!
Double sided tape + clips. Water, dust and grime deteriorate the tape on the underside of the car. Plus it's super easy to line up with the clips.
    • I like it when the counter chick leads you out the back into the racks and says "have a grub around in here and see if you can find what you need. I'll be back in a few minutes. Just left me in front of a massive motorised shelving system and 2-3 million fasteners, so I could find a peculiar SS shoulder bolt with cap head. Gotta love country towns.
    • I used this https://osgiken.com.au/product/os-giken-os-250r-lsd-gear-oil-80w250-1-litre/   shut my nismo 1.5 pro up by heaps…. Not silent though. Gives the car character and personality. It ain’t a carolla. If you want silent, put a quaife in it.
    • It's about the same time for me from Bunnings, or the Fasteners. My big push away from takeaway food, and gluten in general keeps me away from the Bunnings Snags too! Weather up here, I've been out for two walks today in the beautiful sunshine. Had a few little drizzles, and some wind, that honestly, a tin of beans and I could compete on how harsh she blows Thankfully, being this bit inland, we're not getting anything much really. Will probably pick up a bit more when/if Cyclone Alfie decides to come ashore. A few areas in the GC though, and south into NSW are really getting smashed though! Right now, I'm just annoyed Alfie hasn't hit, as I'm not allowed to crack into the BBQ foods like the bacon and eggs until the Cyclone hits "In case we lose power"...
    • I love fastener joints, the price difference between them and joints like Bunnings or Super Cheap is amazing, and they either have exactly what you want, or they can get it to quick They have even given me some for free when I only needed a couple of specific size In saying this, I have paid premium for fasteners from Bunnings if they have the sizes I need, but only for convenience really, as my local is only 10 minutes away, the Sushi joint near them is also a consideration  How's the weather Matt? Stay safe mate
    • Wideband is worth setting up if only for tuning purposes. I would not mess with the ignition system unless there's a misfire. HKS crank trigger is popular out here for the relatively easily sourced Denso crank sensor, not a bad idea to install as well regardless of power level on a standalone. Boost leak test is worth thinking about. Oil pressure sensor tied to a fuel cut isn't a bad idea either. Getting the tune figured out is a good idea. Without putting eyes on it and getting under it there's no way for us to tell you exactly what it needs but most likely you're down to the last 10% that will make a big, big difference in how happy you are with the car.
