Hey guys,
New to the forum and new to the skyline world. I bought a 33 two weeks ago. It has a full 3" exhaust with cat and hotdog muffler and originally had a cannon. I got a hold of a set of 3" stainless straight pipes and put them on mainly because i dont like the look of cannons but since have noticed a power loss top end. It just feels a lot slower, even changed the way it hits limiter.
So I'll probably put the cannon back on to gain the top end performance back, but I don't really want to. Is there anything else I can run thats not a cannon or straight pipes and will do what I want?
Thanks in advance.
I assume by "straight pipe" that you mean you replaced the rear muffler with a section with no muffler. Or possibly that you replaced the whole lot including the hotdog, meaning that you have nothing but pipe behind your cat. If either of those cases are true, then I would expect;
  • It's horribly loud,
  • It probably sounds like arse raping a donkey,
  • It shouldn't do ANYTHING to make your car make less power.
So either it just feels slow because it sounds so bad, or just possibly, and I mean JUST, it has increased air flow through the engine sufficiently that the shitful R33 ECU has decided to put you into R&R territory and is calling a halt to the fun. In which case, it's not about the exhaust, it's about management.
Its just twin stainless pipes from the diff back, the hot dog is before the diff. It sounds good up until 4000rpm then has horrible stainless Eco. And was thinking it'd be the pipes cause who ever made them was pretty dodgie, like where the Y pipe is they've slipped 3" pipe over it and left the end of the Y pipe that should have been trimmed flush on the inside of the 3" pipe there, if you know what I mean, so could be hitting that and restricting it or f**king up flow?
As stated previously, any power difference is usually placebo effect. Tuck a quality 3" muffler up in the standard cavity and put a dump pipe on it. Having idiotic cannons hanging down on stupid angles is a good way to get a cops attention.
One suggestion, focus on keeping it legal or stealth as possible unless you want to get pulled over or defected regularly. Something custom is usually a lot better and works out well depending on the purpose of the car.
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
