My 2001 M35 with 115,000 kms occasionally blows blue smoke on start up.
Only on cold starts too.
Also the other day going down the Roseville bridge , I saw a bit of blue smoke briefly.
Engine seems healthy, starts and drives beautifully, plenty of power.
No smoke on accelleration or decelleration..
Turbo is quiet, no signs of noisy bearings, just the normal whistle.
Signs of a dying turbo ?
From what I've read, stock turbos only last around 120k on average.
Or maybe something with the engine?
Or Maybe wrong oil, (too thin) ?
Any thought ?
thanks...
Edited by conan7772
https://www.sau.com.au/forums/topic/455737-blue-smoke/
A turbo can and should last the life of the vehicle, unless your hammering the shit out of it !! This bull shit about replacing them is just that BS unless there is actual physical internal damage to the turbine fins, some turbo's use roller and some use slipper bearings that rely on good oil pressure as they literally run on a film of oil like a hovercraft and once the engine is stopped the reason why you hear a slight noise as the turbine slows to a stop. There may be a need to replace the bearings and seals yes but replace the Turbo that is just false economy!!
Is the smoke continuous when cold or in puffs? and you say only cold ! ie overnight stop or parked for a bit when out and about ? as that can indicate that you may have the potential for a valve guide/s being a little worn or some something as simple as stem seals. while annoying is not life threatening to the engine.
I run a Multigrade 10W-50 Synthetic designed for Turbo applications from Penrite So yes Oil could be a consideration,
Change it to a heavier grade or even a straight 40W as a test. if there is no smoke then you could well have worn guides, rings or other areas where the thicker oil can't pass There can also be oil leaking past the Carbon face seals in the turbo until it's warm that is giving you smoke too.
Edited by MozzMann
https://www.sau.com.au/forums/topic/455737-blue-smoke/#findComment-7516571
lol.
It's ok, it's just the PCV oil running down inside the plenum and sitting on the valve overnight. Shelberight Alex. ;)
I'm so sick of "Know it all's" like you popping up and telling people the wrong things... :rolleyes:
Alex; please listen to Scotty; disregard all the other "opinions".
Keeps the cash in your pocket a lot longer.
  • Like 4
https://www.sau.com.au/forums/topic/455737-blue-smoke/#findComment-7516700
Cool story bro.....
https://www.sau.com.au/forums/topic/455737-blue-smoke/#findComment-7516771
^ 4 ^5 Well if people don't want some educated mechanical input I shall cease .
It was almost unrecognisable as helpful advice, and easily identified as an uneducated rant.
Your informed debate on turbocharger life bears no resemblance to the reality of Stagea turbocharger ownership; especially NM35's. Turbos on this particular car routinely fail between 100000 to 160000km.
The Japanese service schedule actually requires replacement of the turbo at the 10000pkm service.
This could certainly not be misconstrued as "The life of the vehicle".
Using excessively low viscosity oils in such a close tolerance engine is also a very bad idea.
Assuming you know how these engines behave based on previous experience, routinely ends in tears with this particular engine.
There are a number of people in this forum who can be trusted implicitly, as their knowledge is absolutely second to none; I wouldn't be following yours based on what you've said so far.
  • Like 4
https://www.sau.com.au/forums/topic/455737-blue-smoke/#findComment-7519679
What these aren't just like an rb? Sheeiiitt
  • Like 1
https://www.sau.com.au/forums/topic/455737-blue-smoke/#findComment-7519683
As daleo has said you have proven to have no knowledge about this car, your post in this thread plus the other threads you have attempted to display your almighty knowledge apon have shown you may need to sit back and read for a while before trying to hand out your miss informed information
https://www.sau.com.au/forums/topic/455737-blue-smoke/#findComment-7519688
And prey tell WHAT makes you the resident expert ?
I am not saying I am the resident expert, but I have spent a hell a lot of time and money modding my M35. So I may have a little knowledge.
What I do know for a fact is that what you have said in this thread regarding changing viscosity of oil will affect the variable cam as it has a major part to play in the way they work. I also know as dale has said above that the stock turbo is listed as a replacement part for the 100k service as a directive from nissan them self. So unless these cars are only meant to last 100k I am pretty sure they aren't designed to last the life of the vehicle. This along with some of your other comments regarding how the 4wd system works which was very very wrong shows me that you have no idea and should probably learn about what you are talking before going on crazy rants and giving out terrible advice.
Edited by Brick
https://www.sau.com.au/forums/topic/455737-blue-smoke/#findComment-7527597
Normally when I join a forum; I don't start ranting at guys who've been there for years, as it generally makes you look a bit foolish.
If Mozzman has some useful information, or maybe some first hand Stagea experience to offer; I'll be happy to check it out.
Generalised ranting doesn't really impress me much; actual knowledge does.
  • Like 4
https://www.sau.com.au/forums/topic/455737-blue-smoke/#findComment-7527622
Yer, I wouldn't be doing that on the VQ though. Idle relearns are a little more difficult on the M35. Just let it burn, it's what the manufacturer wanted it to do, must be for emissions. lol.
OK have to re-visit this issue, smoke getting worse, more frequent and more of it.
Mainly on decelleration.
Haven't seen any on start up for a while and seems clear onn accelleration.
Again, turbo sounds good, spools up fast and is boosting nicely.
Does the PCV really allow this much oil to vent normally ?
Another thing to mention is this car has a straight through Jasma exhaust with Scotty dump.
Maybe as there is little or no back pressure, the PCV sucks oil ?
Any thoughts ?
cheers
https://www.sau.com.au/forums/topic/455737-blue-smoke/#findComment-7533831
If the PCV is faulty it may be causing oil to be sucked into the plenum, but more likely the rear bearing in the turbo is on it's way out. You could probably check it by dropping the PCV hose to the ground temporarily and blocking the plenum fitting to bypass the PCV.
I would say 'drop the dump' and check the shaft play on the turbine wheel, but that's quite a job in these. When you say the turbo sounds good, I assume it has that standard M35 turbo whine?
What grade oil are you using? Do you know the legitimate K's on the engine?
https://www.sau.com.au/forums/topic/455737-blue-smoke/#findComment-7533858
yep stock turbo.
I've driven 5 in all so the sound is normal, quieter if anything.
Boost is good, mixtures are still good, hardly any smoke whilst hard accelleration and it's black .
If the turbo is going, wouldn't it leak under boost ?
113,000 kms genuine.
not sure of oil as previous owner was doing changes and he can't remember what grade.
What grade should it have ?
Faulty PCV sounds like a good place to start.
Performance and idling is perfect though.
cheers
Edited by conan7772
https://www.sau.com.au/forums/topic/455737-blue-smoke/#findComment-7534027
    • Can perhaps see how the R33 appreciators would think so.
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
