United are really pissing me off with their market monopolisation price hike
Can someone explain to me E10 being cheaper than unleaded but E85 being on parity or more with it, as anything other than a cash grab at the niche market who supported United in unrolling and maintaining their E85 investment?
E85 used to be about on par with running 99 octane and the advantage was a big power boost and slightly smoother engine. This is negated when it starts to cost more :(
They deserve to lose the market to the 98 octane big boys Shell and BP, which is probably what will happen if they can't supply it for cheaper. The hike would surely have made a dent in people switching to it.
Yeah I brought this up somewhere as well, it's absolutely disgusting, especially when e flex is consistently 20c/L cheaper. Do Caltex hate making money or something? Of course not, that's how much it should cost.
I'd understand being a few cents a litre more than Caltex as they use 98 for their 15% unleaded (and the wank factor of 'the official fuel of the V8 supercars') but 20c is obviously a gouge. The problem is, most people will just pay it
That's what it comes down to in the end. If people will pay it, they will charge it. And even if it was $2/L at the pump, it wouldn't be the end of the world really considering the extra power you get from it and the convenience of having it at the pump compared to storing it somehow illegally at home. And I'd rather it be a bit of a ripoff but still be convenient like that rather than have them drop it completely.
We don't buy E85 for economical or green reasons, it was just a nice coincidence that it was fairly economical as well as better in the past.
The main reason I think it's becoming less economical compared to 98 right now is because the price of oil halved very quickly and the price of ethanol didn't. Once oil goes back up again relatively, then E85 will be an economical option by comparison again. So hopefully United stays with it until then. It's not like the price of E85 has gone up too drastically has it? It's more that unleaded has gone down.
As a separate issue, it seems like in the last month or so, the price of unleaded has gone up and stabilised at that higher price, which I can't really see a reason for. It went down due to the drop in oil prices, but it went up a bit again without the price of oil going up as much. Seems like their margins on unleaded have gotten bigger, rather than their costs.
Slightly off topic but whats the cheapest 205l drums of E85 people have found? Im up in Cairns so no pump E85 up here. Also if anyone has any suggestions that may help with transport, thats what really kills us up here. Pm me if thats better.
If that was true then E10 wouldn't be cheaper than unleaded; it would be more expensive if the ethanol was the expensive component in it's mix, but it's not.
It's jumped by nearly 20 cents a litre and this happened around the time Caltex pulled out of e-flex. They're simply charging it because they can, which is fkin shit for people like me who got on it a couple of years ago and gave them a reason to even stock it. They're not supposed to be making that much money on the shit and economy of scale says it should be getting cheaper with more widespread use, not more expensive.
I bet you if another chain came out with an E85 mix they would instantly take 20 cents a litre off it.
Also $2 a litre might be fine in a race car but if E85 goes up past $1.50 in a street car, with no jump in the price of unleaded or 98, I won't be using it anymore.
So now there is only one outlet for E85, no wonder United upped their price, supply and demand = they can :(
Before the oil prices dropped I was paying $1.68 for 98pump up here. I do not remember seeing a United station anywhere up here so I guess there is not much chance of getting it ???
Maybe if Caltex had an extra 20c a Lt on the E85 they would still be selling it ?
  • 3 years later...
Lowest I got was 99 cents; they were good times indeed. Cheaper to run than 98 and more power. Now it's more expensive to run but still worth it for the powaaaa...
    • Hi all. Been a while but things are moving along. I just have something that I am wondering about. Since I will use OEM turbo oil pumbing, I got myself a new bolt, the one that goes into the engine block oil feed. As I recall (and see visually) this bolt comes restricted with I think a 1.7mm hole? Not quite sure but it was something around that size. The turbos have 1mm restrictor bolts installed, as necessary due to ball bearings and my higher oil pressures. Can I now just use that OEM bolt with the 1.7mm hole in for the engine block or will this actually be too much oil flow restriction and I have to drill it out first? In my head it would make sense for the bolt to be at least 2mm wide as both turbos take "1mm of oil flow". Do let me know if my logic is flawed here, I just want to make sure I don't kill my turbo bearings with too little oil. Don't know if I can trust the saying I read somewhere that ball bearing turbos essentially only need an oil mist
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
    • Yeeeppp, been following a lot of the testing on the latest Xona stuff and there are some mental results.  He also went over 1000hp @ 4 hubs on his Mainline with a XRE6364S (63mm) which was also well into the 20psi range before 4000rpm on a 2.5. Crazy stuff. Fwiw the XRE5964S is basically the modern equivalent of their old HTA3582 - would drive nicely enough on an RB25 or 26, but proven capable of a huge amount of power if you want to spicy with rpm tho even at sane boost levels will make stout numbers
