What kind of gains could I expect with cam gears and the stock cam?
Boost on a little sooner, more power/torque everywhere in the curve.
That was my experience with 34R stockers anyway.
You're best off leaving the stock cams in and using adjustable gears. With adjustable gears you can get some good gains, depending on the amount of time spent dialing in and setting up the cams to suit your tune. That way you'll get the best response.
If you weren't going to keep stock, Type R would be recommended next before Type B. As others have mentioned, you'd lose some low down response with Type B for top end power but in reality having low-mid range power is much better.
310kw on E85 seems slightly low for those turbos also. Unless the boost is down at a lower level then it would make sense. Adding cam gears and more boost (21psi area) you could get up to 350kw provided you don't have restrictions elsewhere.
There is a bit of information available on the Tomei Poncam range and the results obtained from them on a variety of setups.
How can type bs make a gtr with gt-ss drive Terribley down low
They already responsive as f**k ! I been in my mates before and after type bs noticed no difference down low
I should find out what gains he got with cams....
You should give Racepace a call and ask them what the think about type b's. I'll give you a hint, they got ripped out, sold off and went back to stock. What looks impressive on a dyno doesn't always show what's going on actually driving the car.
Thanks again everyone.its clear that aftermarket cams are not worth it on a 2.6 so cam gears have been ordered and I'll post the results when it's done
Stock cams/cam gears, -7s and E85 over here. 325kw with all the mid range you could want.
As Piggaz said, a dyno graph won't always show how the car drives.
I was making 320kw on 98 with:
-7's
Tomei Type B's
Tomei cam gears
Standard Dumps
Nitto bottom end
It's currently getting fixed up, and then put to E85. Don't know what ill get there....
Without naming names, From what my engine builder reckons RBs don't need massive cams
They make plenty of power and response on very low duration cams.
Most of the time the big duration cams have a pussy profile so that's why you often see the curve move a lot to the right on the graph.
People often forget its not just the cost of buying the cams, but the hidden cost of installing cams on an rb can be a shock too
    • Tape some wool onto the vent then take it for a drive I did this to my reverse cowl and was instantly unhappy, as anything over about 60kph would have the wool enter the engine bay, thus just adding underbonnet pressure and stooging my coolant stack, it did let alot of heat out when stationary though, which really didn't help once the car was moving, with the reverse cowl you could watch the coolant temps cheap up the faster you went on the hwy, I assume it would be alot worse doing track day speed With the vented bonnet (just after the radiator and about 1/3 up the bonnet) on my old R33 the wool on the leading edge sat at about a 45° angle as air poured out of it From looking where your vents are, and their size, I believe you should be fine at speed and air should be evacuated from the engine bay, I think it will be a night and day difference when stuck in traffic though for removing the trapped heat, and not sitting there cooking when parked up after driving around... #convection  Post wool tuft pics and data for science  This beastie is one nice and unique rig, enjoy
    • It is possible to do this stuff for "cheap". But you need to be able to get deals on all the bigger items, and it really helps if you're fully capable of doing your own work. As soon as you're paying retail for new parts, or buying "kits" because you can't fabricate necessary bits and pieces, and if you really need someone else to take the reins of doing the work because you don't have the space/time/skills/confidence to  rip deep into the car and put it back together in a working fashions.....then you pay. And these days, pay means a lot of money. You'd think things would get cheaper, but they don't. They just seem to keep getting more and more expensive.
    • It’s almost the price of an engine build, you won’t have anything to bolt onto it though
    • Hopefully it's enough to help with the temps! I was also only shit stirring, regarding Murphy's Law basically. I've found, what ever spare parts I have, are the parts I don't break. Ever. Also have never had issues with oil/spinning bearings until I put oil pressure gauges on the car. 😛
