If you have time i would source a kit from the UK. Its the only place that seems to make the heater hoses for gtst (in silicone hose) think i ordered these from boost junkie or something along those lines
The rest of my hoses are JJR im fairly certain. Its silicone hose, works fine
Oem doesn't leak tho, which if you're happy to have to retighten all the clamps every so often to fix the leaks then yes it worth saving the $350, I am a do it once kind of person
This is from personal experience on my own car
  • Like 1
But Cal don't you have a 25, not a 26.
Under the plenum on a 26 is horrendous and you don't want to have to go back to re-tighten anything. (not that you could anyway)
Apart from the coolant hoses, there's the vacuum ones as well.
Stole this pic of a silicone hose install and below that mess are the water/oil cooler hoses.
I bought the Autobahn88 silicone hose set, fitted the easy one across the front of the cam belt and it pushed straight off, diameter just not right.
So that set went in the shed until I can afford OEM.
$350 sounds crazy cheap for OEM though???
Ahha i knew there were more hoses but didnt quite realise there were that many more haha. I thought mine was bad even with 1/3 of them deleted.
Lets put it this way. If you buy shit quality hose you'll be doing it again once they split or fall off, lol.
I presume the JJR is okay but the best would be OEM. If you calculate the efforts spent on removing the plenum again to do the job again if the kit fails you'll see why it's worth it.
    • What ECU is on your car @silviaz? You can just change the idle target table yourself and the IACV duty cycle. Noting that if you play around with the screw you'll also need to revisit the idle base duty table as you will end up offsetting the lot. Another reason why DBW is superior, there's less mucking about.
    • Yep. Saw that on the image above but, wonder if it makes more sense to clean out the iacv because let's say in theory mine is dirty and if I clean it the rpm will drop. If I first go to my tuner to drop the rpm and then go to clean my iacv won't it drop further or is the rpm a fixed number?
    • Yeah it was a good result, and confirming the car is full of fluids and all interior etc in, other than fuel. I think a few pages back (maybe many pages!) he mentioned some serious lightening in the doors with the chassis punch, might have been done elsewhere I hadn't seen yet too
    • He still had the suspension dialled in for him! I would have sworn the lowest weight he ever got to was 1300kg though Maybe Neil had been drilling a LOT of holes somewhere you haven't found yet... 😛 Or has he also drained all the gearbox and diff oil out too, between it, and a tank full of fuel there's about 65kg to 70kg to add back in I'd guess. 😛
    • Yeah this isn't a super complex shape, but I was still happy to buy instead of fab version 1; very little in a modern can is a flat surface, and that is true here again - the undertray has about 50mm in height differences that I would have had to work out myself. I will probably make something more substantial before it does any rally, I don't think 1mm steel is too much use as a bash plate. There is also cooling to think about, Z1 have done a bit of development and have some air holes and louvers in the shape, will see how that works out too
