Well I'm starting to compile a list of the parts that will be needed for my old 22 year old Peugeot 306 XR. On start up she does smoke quite a lot which I'm suspecting is the valve stem seals purely because after a while the smoking settles down. I've owned the car for almost 7 years (Bought her in November 2008) and she has been off the road now for almost 4 years. In total she has clocked up 153,328 miles which isn't too bad at all for an old 1.4L engine.
Engine is a TU3 series 1,360cc producing (once apon a time) 75bhp which sounds like nothing compared to a lot of cars on this forum. The car has no rear window which was my fault but as for corrosion it isn't as bad as it should be for a car of this age, there is quite a bit in the engine bay which I want to deal with but underneath it isn't too bad. I took the pictures with a stock digital camera so I am far from an expert at it so please bare that in mind :P
I've bought some decent 10-40w engine oil from the store that I work at, doesn't have to be amazing as I just want something clean because the oil has been sitting in there for almost 5 years, I have a new filter and some Wynns engine flush for my day off when I have time to do it. I've been told an numerous occasions to scrap it and quite a few times I've tried but couldn't bring myself to do it, I'm stuck with her and that is OK to me and since it is a 1993 XR there are only around 500 left on the roads in the UK so all the more reason to keep her and once I can find a garage or somewhere to rebuild her I'll make a record so I can put together a build log of some description.
https://www.youtube.com/watch?v=NdGoBJXEp0U
https://www.youtube.com/watch?v=yk5Hgk7JNcY
Edited by FireFox-89
https://www.sau.com.au/forums/topic/455814-my-poor-peugeot/
No-one wants to see your old Peugeot in a Skyline specific section, did you misplace it here? The new Euro section above might have been better. :P
Cold start smoking can just be a little blowby causing excess oil to drop down from the PCV overnight and sit on the valve, nothing to worry about usually, unless it does it all the time.
  • Like 1
https://www.sau.com.au/forums/topic/455814-my-poor-peugeot/#findComment-7523374
That would have been better but couldn't find it and also it does it all the time on start-up.
https://www.sau.com.au/forums/topic/455814-my-poor-peugeot/#findComment-7523937
All the time, meaning constantly while running.
As a test just drop the PCV off the intake for a few days, and plug the intake side only. Should prove it's the PCV or not pretty quickly.
All the time meaning on start-up. I leave it running for around 10 minutes and the smoking calms down. What is the PCV?
https://www.sau.com.au/forums/topic/455814-my-poor-peugeot/#findComment-7524154
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
