So currently I have a 2009 V36 Sedan, and I am very happy with the car mind you despite some harshness in ride quality here and there.
But before I decide to blow too much money on modifications and things, is it worth upgrading to the 2010+ models?
I realise that there are minor improvements such as the fog lights, front bumper and upgraded interior bits (correct me if I'm missing anything) and the aftermarket parts, more so bodykits etc fit on the 2010+ more than the grey period between 2008 and 2010.
So should I trade it in a bit later on to get a newer 2010+ model or is the difference really minor and not worth it?
Cheers guys
https://www.sau.com.au/forums/topic/455822-2010-v36/
http://www.sau.com.au/forums/topic/430930-v36-rev-probs-firmware-update-anyone/
more apparent in the early pv36s i think
the newer kv36 models have it a little when decelerating mostly, happens every now and again to me, just a bit jagged like the rev matching goes a bit hard
https://www.sau.com.au/forums/topic/455822-2010-v36/#findComment-7518696
I have a 2010 v36 and I have done around 4k driving in it so far, both freeway and residential driving. I have not experienced anything like what people have described, well not yet. I have found at times the car sits on high revs longer than it should. I have a 370GT.
When I was looking at the v36 I discovered there was a vast difference between the 2009 and 2010 v36's interior and the materials used. That was the reason I went for 2010. I never noticed much of a difference between the ride/drive quality but then again it was only a quick test drive in the earlier models.
https://www.sau.com.au/forums/topic/455822-2010-v36/#findComment-7519083
    • Yeah, you are right. It seems easier and more reasonable to boost the engine. And as you said the blocks are very similar but the cylinder bores are different.
    • Sound logic, but in actuality way more illegal than just having the wrong pipe. Normally, doing something like that would be forgery. Meaning you may have certain documentation for vehicle parts, but the actual parts are different ones and you just assign them the numbers and badging from the documents. But nevermind that. Nonetheless, I AM curious if this pipe was ever made by any official manufacturer this way, because I honestly am not familiar with this pipe layout and shape. As I will be putting on the HKS Silent Hi Power once my exhaust gaskets arrive, as long as it sounds right I will just roll with this front pipe. I can always order the actual Mines part if I run into legal issues. It would be an unnecessary expense as there is lots of other problems I have on this car as of now.
    • So, weld a plate with the Mines logo laser cut into it, onto it. Instant Mines pipes, whether they were or weren't originally.
    • I don't know if the blocks are "the same". They will be very very similar. Obviously, either the bore or the stroke is going to be bigger on the 20. If the bore is bigger, then the 18 head is unlikely to fit properly. If the bore is the same, then you can almost certainly fit the CA18 head, but there migth be a few fun things you have to do to make water galleries (or other things) line up properly. Or... it could just be real easy. Is it worth the effort? Almost certainly not. You can make nearly as much power on a 2 valv ehead as you can on a 4 valve. There's not any "magic" in a 4 valve head.
    • Yes, me too!!!!  I need to find a something that has all the abbreviations for what these cars have LOL
