Hi guys,
Just bought some nice factory Rays forged 19" for my V35 so finally I can get rid of the damaged Enkeis...
I love these wheels; perfect design, light weight, good brand, good size. Shame they are too damaged (for my standard).
Two 19*8.5 in front, two 19*9.5 at rear. Previous tyres were K19 245/35/19 all round, perfect fitting.
Offset +22 I think (as the photo suggests). Fits a V35 perfectly.
5*114.3 PCD like most modern Nissans.
Not an urgent sale so may ask for EOI too - if I can't get a good price off them I might just keep and refurbish them for my next V36.
Asking $1.2k ono, located Eastwood, NSW. PM me or text/call 0430 triple 7 double 8. I work 9-5 on weekdays so please call after 6, or text any time.
Prefer local pickups (or I can drive to you if you're not too far away - but won't drive for inspections sorry) but shipping can be arranged at buyers' cost.
Good:
Design
Weight
Brand
Size
Bad:
One buckle on outer ring - wheel itself is straight
Bad, I mean BAD gutter rash
Scratches here and there
Only come with 16 nuts (RAYS nuts - I was amazed when I saw them too)
No valve caps (ordered some Nismo ones at the moment, so may provide a spare set after I get the nismo caps)
Photos will tell the story.
  • 3 weeks later...
    • Duh... to answer my own silly question, it's actually described in the FSM... ...400 pages away at the end of the manual, for RB25DE/DET signal descriptions, it cites the TPSwitch signal action, is dependent on the TPSensor value ~ this tends to infer the builtin POT voltage signal is the primary, and the switches are fallback/secondary should the POT fail/TPSensor signal lost (and switch alone with no TPSensor signal allows for base idle speed setting).... makes sense... they (TPS units) used to fail/wear the POT with time, they're not exactly built to last ~ having the switch as a redundancy gets around this...(or, it's less likely both signals would be lost as they're on different power rails)... and of course wrt RB26DETT, you have to electrically disconnect the IACV solenoid from the harness, to defeat idle air control...
    • Dose is unaware just how much fun 145-150kw would be in a 2.5L NC MX5. It would be one of the most fun things to drive to ever grace SAU.
    • Same thought crossed my mind ~ depends on how one connotes 'stalling'...ie; gets a rough/stumbling idle as it get warm until it stalls... or... idles ok and simply falls-over when it gets to temp... ...you can test the whole circuit with a couple of resistors ...unplug coolant temp sensor, bridge terminals with a 2K7 resistor (ECU will do cold start), or with engine warm bridge with a 330R resistor (ECU will consider engine to be at normal operating temp)...it's a quick way to check wiring integrity/ECU response when you don't have a multimeter handy ...
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
