  • 1 year later...
On 4/20/2015 at 10:40 AM, scotty nm35 said:
I thought the existing child restraints were ok these days as they realised the Aus standard ones were inferior? Perhaps I am wrong though.
I'm starting to look into this, will probably have make 100 calls to get to the right Government departments but i will update you guys.
Ps. Rang Northshore Prestige but they have no idea as they said they're only providing the Compliance Plate and that's about it.
Would be very interested where you get with this as I would like nothing more than to do away with the terrible anchor point install that was done on my car.
As an aside, anyone know how the Japanese child seats are installed? Do they use the "luggage" tiedown points or something else?
I would say that they use the tie down points. If not there may be a thread point you can use and drill a small hole in the floor panel and use a floor type harness point.
Got no where yet ........ rang around 10 time to difference Agencies
...but here is an interesting article from Japan Times back in 1999
http://www.japantimes.co.jp/news/1999/07/05/national/parents-unprepared-for-child-seat-law/
Quote
To avoid misuse and mismatching, Toyota Motor Corp. and Takata Corp., a major seat-belt maker, have jointly developed a new child seat based on a standard called ISOFIX that was drawn up by the International Standardization Organization.
The new seat, to be introduced in August, has a base that locks easily with hooks set in the rear seat of the car. Connectors attach the seat to the top of the base.
Toyota spokeswoman Hitomi Hayakawa said the new seat is easy to install and can be fixed firmly to the interior of the car without a seat belt.
  • Like 1
Ok
I got a reply from the department of infrastructure ......sorry i had to remove his/her name as a part of the email disclaimer.
Quote
****** Ge***** <Ge*****.******@infrastructure>
12:21 PM (5 minutes ago)
to me
Dear Mr Kingdick,
Nothing is confirmed at the moment. I can’t give you any confirmation as to how the new system will look, operate nor what will be deleted, added or modified.
The system is still being developed at this stage with nothing set in concrete.
Anything you hear as being added, deleted or modified in the new system is guess work and should not be interpreted as fact.
Kind regards
cid:image001.png@01CEB48B.B2C9B360
Vehicle Safety Standards
RAWS
02 62746549
Isofix is the standard everyone manufactures seats to except stupid Australia.
They have done for many years now; but ADR refused to validate the safety of the seats or the fixture points.
All European cars sold in Australia have been fitted with ISOFIX mounts for years now
ADR have been protecting our lazy, stupid, backward child restraint manufacturing industry because they refused to adopt the global standard, as it would open them up to competition from far better quality equipment.
Due to the death of our Motor industry; ADR was forced to accept international standards which far outstrip any local testing, as legal, and this has opened the way for ISOFIX seats.
  • Like 3
    • Lucky pick up Best to find these things before something horrible happened to the yoke flange thingies I would hate to think what would happen if it dropped the tailshaft  Hopefully the holes are not flogged out in the yokes and it was just the bolts that got munted  As for the hand brake.....ouch, look like the disc got rather hot, and I assume smokey, I recall when I had a front caliper seize on the Commodore, there was lots of smoke and the disc was glowing cherry red when I was able to eventually stop and have a look, and stopping a big heavy car, going down a big hill with some rather high RPM down shifts and some hand brake action is something that makes you think hard about life
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that one side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
    • Very interesting, im not sure how all those complications fit in to running a haltech instead of a stock ecu but I'm starting to think I'm a bit out of my league.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
    • Don't assume the AC relay signal from the ECU is +, some models including Stagea use an earth trigger.
