Hi all im selling the following off my R32 gtr
Reason being is that im changing the whole setup and nothing is required
-OS Giken Twin plate clutch with plenty of meat left to suit Push type ! Was in perfect working order when removed !
Will also come with ARP Flywheel bolts -Any enquiries regarding clutch text this number -0455364963 He is after $1000
- Tomei Cams inlet and exhaust (was told by previous owner that they where "stage 2s"
-Greddy cam gears inlet and exhaust
Parts numbers on the cams -a2691x
-a2691xr
After $500 firm for both cams and cam gears
-Power fc to suit r32 gtr (does not have hand controller) $400
-JJR oil catch in decent nick with hoses to suit (sits above rocker cover) $50
-6 sard 800cc injectors $280
-Apexi Boost gauge $50
-Trust rear turbo house heat plate $80 (to suit .82 4 bolt style )
-Turbosmart 48mm Progate $250 firm!
-GT35r chinese copy turbo with dump pipe $250 firm(was making 380kw on 21 psi)
All parts are located near Cecil hills nsw
Only looking for local pickups will not send anything interstate
0431 635 372
    • I recently got their dbw 74mm throttle body and pedal kit. It is sensational quality especially the wiring harnesses. Unfortunately I can’t answer u about the fitment to stock inlet manifold as I’m going Rahjab Racing forward plenum. Only one thing to be careful of is understand u have to pay gst and import fees if your purchase is over $1,000 in one shipment.
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
