Hi Guys
Please, no flaming, I'm asking a simple question not opening a debate.
Is anyone using one of the Knock-Off style TiAL External Wastegates (Commonly available from Ebay for around $160 and can shed some light on their quality? Obviously, wont be as good as a genuine TiAL Item, but for a street setup, which doesnt get given hell it's a possibility it could be suitable if they operate properly.
Water Cooled Version:
http://www.ebay.com.au/itm/NEW-44mm-V-Band-External-WATER-COOLED-Turbo-Wastegate-performance-black-/201125634800?pt=LH_DefaultDomain_15&hash=item2ed405a2f0
Standard Version:
http://www.ebay.com.au/itm/44MM-V-BAND-WASTEGATE-High-Flow-Peformance-TiAL-Style-V44-BLACK-/261853156689?pt=LH_DefaultDomain_15&hash=item3cf7aa1551
Cheers
https://www.sau.com.au/forums/topic/455893-tial-style-external-wastegates/
I guess your boost cut adjustability could add a safety for that, most aftermarket ECU's (Maybe Nistune too) have adjustable boost limit?
Thats strange, how did moisture get into it? I would assume the raw materials of even a genuine one would have had a problem in that situation?
All good points though..
Edited by boothy_99
My mate's car was an EL Falcon on LPG. The exhaust was always a bit wetter than when it was on petrol. But you know what happens when a car is in the workshop for a while. It gets started, moved 5 metres outside and stopped. Then again, and again and again. Always running cold for a short time. Makes for a very wet exhaust. The rather crappy copy wastegate's materials rusted. Same mechanic had never seen it before on good quality gear. Was always paranoid about it afterwards though.
  • Like 1
Hi Guys
Standard Version:
Cheers
In what way do you think it will be superior to the stocker you have on now?
We all know external gates have superior boost control than that of a internal gates, I have a custom low mount manifold with the outlet on it for a 44mm V-Band external gate which I intend to run plumbed back into the system on my Stagea RB25DET-NEO
Some things are not worth going cheap on. This is one of them.
Hi Ben, I am the fella that came and bought your Stagea Exhaust. I dont see if this functions properly, it should be cancelled out. I mean, everyone sings praise for Kando turbos which are copies of popular items and operate well on their own with a significant reduction in price.
Ahh, we know each other!
I have personally considered buying a knock off waste gate. And decided against it.
The reality is if it stuffs up as described by GTSBOY, boost is uncontrolled. Also, if the diaphragm breaks boost will be too high.
Relying on engine management to cut power etc is not the best way.
A knockoff turbo if it breaks it won't kill the engine. I would sooner use a knock off turbo than waste gate.
I had a fake one pulled apart the other day (Atleast I think it was fake as I got it cheap, I sold the whole setup on after rebuilding the turbo anyway) and the Diaphragm material was very good quality, similar to the ducting we use in aviation bleed air plumbing (Hi temperature).
I'm more looking if someone is using one and to see their response.
E.G, Rock solid boost control, with consistent control rather than an expected cheap quality of Fluctuating boost, and inconsistent control.
We don't all know that because it isn't true. See for example the Borg Warner range of internal waste gated turbos. If your budget is tight a Hypergear turbo would bolt straight on to your stock exhaust manifold. I got reasonable boost control on my IWG GCG highflowed RB25DET with a Jaycar boost controller!
Having said that for my RB30 I got a Synapse wastegate and using a Link and a Mac valve got pretty much "rock solid" boost
That is a nice boost curve, however I have the external gate outlet, so should utilise the opportunity to run one.
By the sounds, they seem pretty unreliable, seeing as no-one has chimed in with a really good result yet.
Guess I will wait for a second handy to pop up before I get turbo, or just buy new once I have bought a turbo..
I will only sell good Aussie Turbosmart gates these days. I have seen too many issues with other gate brands to recommend them, and you are only talking another $200 or so compared to the cheap knockoffs.
It isn't an item you want to cheap out on, exhaust manifold temps get pretty damn high.
Second hand is useless as you don't get a new flange for both sides.
If you dont want to buy a tial or turbosmart etc. another good option that is cheaper than the others is hypergears 50mm wastegate Ive been running one for 3years and no issues its about the 350 mark I think.
I spoke with Aaron of driftmotion over here. He sells some Supra turbo kits and they use the china gates. He said specifically NOT to use the new ones with V-bands...He said the older Greddy style 50mm and the new flanged 46mm work great. He recommended the 46mm back in the day (when I was thinking about going single on my Supra.
http://www.driftmotion.com/46MM-Wastegate-p/dm513.htm
This is the one he uses on his car.
And...Since i plan on road racing my car I honestly would just spend the money on a proven unit with a warranty...but again safeguards like boost cut could help the issue either way if things went south.
Edited by HarrisRacing
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
