GTR brake upgrade,
I have been speaking to Brakes direct and have got some prices for brake upgrades with a 5% discount on 3 purchases and greater discounts with more interest
Alcon 6 pot fronts 378mm with 2 piece DBA 5000 rotors normally $2997 ($2848) with current discount
Alcon 6 pot fronts 365mm with 2 piece DBA 5000 rotors normally $2697 ($2562) with current discount
Alcon 4 pot Rear 335mm with 2 piece DBA 5000 rotors normally $2497 ($2373) with current discount (works with standard handbrake assembly)
All kits come with street brakes and can be upgraded for race pads depending on what you prefer for aprox $200 more.
Greatest advantage of this kit and reason for the cheaper price is the ability to run DBA rotors instead of Alcons which would run almost double the price.
The replacement cost on rotors is $385 for 365mm and $399 for 378mm each
All kits come with mounting brackets and offer free delivery Australia wide.
If all goes well order will be placed by the end of the month.
If you are genuinely interested please send me a PM as i will be posting this on a few pages.
  • Like 1
https://www.sau.com.au/forums/topic/455896-alcon-brake-upgrade-group-buy/
What do the mounting brackets look like? Can we use standard/existing lines? Also whats the thickness of the rotors and any modification required to fit a 32gtr?
Edited by Jaeyon
i have been told they are direct bolt on with the correct bracket and the original lines should be compatible. i forgot to ask about thickness of rotor tho so not sure, but feel free to call and ask them. brackets will look something like this depending on model
How is the clearance with the 365mm under stock gtr rims? Does it retain the stock lengrh brake lines? (I have HEL braided lines)
Also is it possible to buy just the caliper and adaptor by itself?
Cheers
Cheers
365 clearance will be ok, 375 leaves very small gap, stones get caught and cut into rims as was discovered on a friends 32R.
Also adapters will work fine for your car Tim, you will need to space it out and shave a few mm off the hub to fit
Just an update guys, Anybody who is interested due to being a group buy the wait time on these calipers may be between 4-6 weeks.
We have been offered an alternative which i think is even better, We have been offered a free upgrade to the race version of this caliper.
The racing calipers are 600grams lighter than the road caliper, they have a removable bridge which makes changing pads a whole lot easier, and they come with knock back spring which helps keep constant pressure on the pads which reduces the need to pump the brake pedal when flying into a corner, and also helps reduce pad knock off.
These are normally $1000 more then the regular calipers so a much larger saving then the 5%.
The group buy will begin Monday and be closed by Wednesday at the latest.
If you choose to jump on board just call brakes direct on 1300724943.
PS the new caliper looks much nicer
  • Like 1
No problem, i just ordered mine now.
I also ordering a custom bracket made up for the rear brembos to space them out to run 350mm DBA 4000, 370z discs, with same pattern as the fronts.
Kit includes 2 brackets and 2 350mm DBA 4000 rotos, for $750.
Caliper picture and details for the motorsport model.
Sounds like an awesome deal for anyone looking for an upgrade.
I already have R34 Brembo 4 pots on my S14 and a pair of AP Racing 4 pots sitting around and am tempted to grab the 365mm kit!
Edited by «Cyph3r»
  • Like 1
I'm finding Brakes Direct website hard to get around.
Can anyone comment on the hats and brackets they use? Also any experience with DBA 5000 series rotors vs Alcon would be great.
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
    • So I'm in the final stages of assembling my single turbo RB30/26 and had a question regarding MAP reference points.  I've seen several recommendations such as tapping the cylinder 2/3 ITB, tapping the intake manifold at cylinder 2/3, or using a point on IAC. First two are doable but require permanently modify part and the third is "out" as I plan to delete the IAC.  All that to say my question is can I used the "bleeder" in the center of the ballance tube as a MAP Reference? I'm running a catch can so I don't need it for the PCV system. My thought process is it "pulls" from all 6 cylinder, and it's between the ITB and the cylinders making it ideal for MAP reference according to what I can find. Thoughts?
