Hi all, have been searching for a few days, and can't find the exact cause to my issue. My r33 gtst wont slow down when I deacclerate without the pushing the brake pedal. Mostly noticeable in a car park when doing 10kms it keeps a constant speed without my foot on the accelerator. When I push the clutch in to park it idles around 1500 for 3 seconds and drops to normal. I have cleaned my iac valve, and going to clean my afm tomorrow. Has anyone had this issue before? Any help would be greatly appreciated.
https://www.sau.com.au/forums/topic/455898-idle-issue/
Sometimes you get the check engine light. Sometimes you don't :(
Codes can tell you if you have access via a scan tool
You can use a multi meter to test it on or off the car. - Just google testing 02 sensor :thumbsup:
or just Take it out, visually inspect, clean and refit. Still got the issue then go further :)
https://www.sau.com.au/forums/topic/455898-idle-issue/#findComment-7519513
I cleaned my afm and idles better. Will need to take it for a drive to see results. I put my hand over the afm while idling to see if any leaks and it stalled. Is this normal?
Probably.
That's not a normal thing to do and won't check anything.
https://www.sau.com.au/forums/topic/455898-idle-issue/#findComment-7520698
