G'Day,
The short story is that I need Q45 AFM pinouts - ie which pins on the AFM is Gnd, Signal & 12V ??
The long story is :
My PFC has been sitting in my draw for months cause I thought it was busted.
Recently the Microtech that replaced the PFC had some issues and has gone back to Microtech to be fixed.
Meanwhile, I put the PFC back in (no AFM) and sure enough it wouldn't start.
So I tried my standard ECR33 ECU without the AFM connected (as the Microtech didn't use an AFM) - and yep , starts OK, but won't rev past 2500 cause no AFM.
I connect up my Q45 to the standard ECU to get some resolution the ECU - just for a test - and low and behold - it didn't start.
So I try the PFC without and AFM again - no go.
I tried the PFC with the Q45 wired the way I think is right - and no go.
Out of frustration - I put the Y31/VG30DE AFM out of the Gloria in the Skyline, set the PFC to standard AFM )in etc), and hey presto - it works.. O M F G.
So, I either have a stuffed Q45 AFM or I am wiring it wrongly.
Can those Q45 AFM guys with PFC and ECR33 , please advise the pinout of the Q45 AFM ??
Thanks -
Very happy that the PFC works ! :D :D :)
  • Replies 43
Thanks Phil, Yep - that's the way I had it wired -
Are we sure that this is correct ? Cause if so, looks like I am in the market for a new AFM :D
Megs will the Z32 MAF have enough resolution for my setup ?
According to SK's table - Z32 only good for 255ish RWKW. (100rwkw short for me ) :D
Air Flow meters RWKW & Engine BHP
----------- OD ----- RWKW ----- RWKW ------ BHP ------ BHP
No of AFM's ----------- 1 -------- 2 -------- 1 -------- 2
RB26 ------ 65 ------ 149 ------ 299 ------ 271 ------ 474
RB20/25 --- 80 ------ 226 ------ 453 ------ 376 ------ 683
Z32 ------- 80 ------ 255 ------ 511 ------ 415 ------ 763
Q45 ------- 90 ------ 302 ------ 605 ------ 479 ------ 890
Also , can someone explain please the PFC settings for Air Flow ?
You have all the choices of std AFM, Z32 AFM, Q45 AFM and others.
But on my commander, all actual settings are the same for each AFM you choose.
eg
1. 0.64V 100%
2. 1.28V 100%
3. 1.92V 100%
4. 2.56V 100%
5. 3.20V 100%
6. 3.86V 100%
7. 4.48V 100%
8. 5.12V 100%
The are all the same for each AFM type ??
I don't get it.
PS - Midnight Tuners Unite :D
  B-Man said:
Can anyone tell me - if I get a Z32 AFM then tune the car. Then later if I go a Q45 again, will the car need a complete retune ??
Cheers,
Not "complete" retune, but the readings are quite different between the 80 mm and 90 mm AFM's. It seems to work out about "half" a tune (timewise).
     eg
 1. 0.64V  100%
      2.   1.28V   100%
      3.   1.92V   100%
      4.   2.56V   100%
      5.   3.20V   100%
      6.   3.86V   100%
      7.   4.48V   100%
      8.   5.12V   100%
     I don't get it.
PS - Midnight Tuners Unite :thumbsup:
Sorry for the second post, I forgot to mention this one /|
That's the AFM "correction" table, the actual ramp table (algorithm) for the AFM's is not visible. What you do with the correction table is match an unlisted AFM with one that is listed. You select the closest one in the list to what you are trying to match and then use the correction table to line them up. You do a basic tune of the car with a listed AFM and then fit the unlisted AFM and use the correction table to line up the maps using the map tracer.
Hope that made some sense :)
    • Yeah, nah. I had the actuator rod off it today. The arm will not move at all. Neither out, nor in. Yeah, you'd think so, but I've been thinking about that. Even when the actuator rod fell all the way off at the beginning of this saga, it would build more boost and faster in lower gears than it would in higher gears, and you'd think that that was the opposite of what should happen. But I strongly suspect that there is a thing with the gearing getting the revs to rise faster, that there must be some transient effect with the gas flow rate rising quickly, that you don't get with the more steady state case of the higher gears. Keep in mind - the gate is not shut in either of my weirdnesses. So things are not "normal". We normally think about a turbo spooling up (below the wastegate target) with the gate shut. I have all sorts of mental models running now where the gate is a little bit open, and having it stuck open allowing gas out while it should be going through the turbine has all sorts of weird effects (in these mental models). I'm thinking in the higher gears, the ex mani pressure builds to the point where enough gases spill out the wastegate to just prevent the pressure rising much more at all, or just creeping up, all the whole the revs are increasing and getting closer to the point where a gear shift becomes necessary.
    • Is it possibly wastegate actuator itself is sticking, or even the rod to flapper? Otherwise I reckon things are getting a bit rusty/worn   Also odd it won't boost in 3rd to 5th, but will in 1st, I'd expect the other way around with it slightly open as there's more time on your way to redline for it to spin up
    • Does anyone know ow what these two plugs are for and if they should be unplugged? Just put the dash back together and can't remember if these were plugged in before or unplugged! (Blue and white plugs) 🤦🏽‍♂️
    • Did some FASTing ...got the impression that the actual part# was a moot point ; seems all of these hardlines for coolant are discontinued/NLA... like, I take it you're after the hardline that bolts onto to the manifold...that's NLA according to amayama & nengun .... ...just to clear up some confusion, they typically mounted the AAC valve to the intake manifold somewhere near a coolant passage, so the body of the valve heats up & holds it open when engine's up to temp - no coolant flows through the valve, it's a mechanical, thermal connection.
    • And now the bloody flapper is jammed slightly open. Lazy as all f**k in 3rd-5th (very hard to convince it to make much boost before you run out of revs), but will make 12 psi in 1st, which shouldb't be possible with a 5 psi spring and controller set to <10 psi. Methinks I'm lucky it jammed where it did, rather than fully closed. It's actually a well weird situation. Careful examination of what's happening in the back of that housing when the gearbox comes out and all the other stuff (injectors, AFM retune) is supposed to be done, next week.
