G'Day,
The short story is that I need Q45 AFM pinouts - ie which pins on the AFM is Gnd, Signal & 12V ??
The long story is :
My PFC has been sitting in my draw for months cause I thought it was busted.
Recently the Microtech that replaced the PFC had some issues and has gone back to Microtech to be fixed.
Meanwhile, I put the PFC back in (no AFM) and sure enough it wouldn't start.
So I tried my standard ECR33 ECU without the AFM connected (as the Microtech didn't use an AFM) - and yep , starts OK, but won't rev past 2500 cause no AFM.
I connect up my Q45 to the standard ECU to get some resolution the ECU - just for a test - and low and behold - it didn't start.
So I try the PFC without and AFM again - no go.
I tried the PFC with the Q45 wired the way I think is right - and no go.
Out of frustration - I put the Y31/VG30DE AFM out of the Gloria in the Skyline, set the PFC to standard AFM )in etc), and hey presto - it works.. O M F G.
So, I either have a stuffed Q45 AFM or I am wiring it wrongly.
Can those Q45 AFM guys with PFC and ECR33 , please advise the pinout of the Q45 AFM ??
Thanks -
Very happy that the PFC works ! :D :D :)
  • Replies 43
Thanks Phil, Yep - that's the way I had it wired -
Are we sure that this is correct ? Cause if so, looks like I am in the market for a new AFM :D
Megs will the Z32 MAF have enough resolution for my setup ?
According to SK's table - Z32 only good for 255ish RWKW. (100rwkw short for me ) :D
Air Flow meters RWKW & Engine BHP
----------- OD ----- RWKW ----- RWKW ------ BHP ------ BHP
No of AFM's ----------- 1 -------- 2 -------- 1 -------- 2
RB26 ------ 65 ------ 149 ------ 299 ------ 271 ------ 474
RB20/25 --- 80 ------ 226 ------ 453 ------ 376 ------ 683
Z32 ------- 80 ------ 255 ------ 511 ------ 415 ------ 763
Q45 ------- 90 ------ 302 ------ 605 ------ 479 ------ 890
Also , can someone explain please the PFC settings for Air Flow ?
You have all the choices of std AFM, Z32 AFM, Q45 AFM and others.
But on my commander, all actual settings are the same for each AFM you choose.
eg
1. 0.64V 100%
2. 1.28V 100%
3. 1.92V 100%
4. 2.56V 100%
5. 3.20V 100%
6. 3.86V 100%
7. 4.48V 100%
8. 5.12V 100%
The are all the same for each AFM type ??
I don't get it.
PS - Midnight Tuners Unite :D
Can anyone tell me - if I get a Z32 AFM then tune the car. Then later if I go a Q45 again, will the car need a complete retune ??
Cheers,
Not "complete" retune, but the readings are quite different between the 80 mm and 90 mm AFM's. It seems to work out about "half" a tune (timewise).
     eg
 1. 0.64V  100%
      2.   1.28V   100%
      3.   1.92V   100%
      4.   2.56V   100%
      5.   3.20V   100%
      6.   3.86V   100%
      7.   4.48V   100%
      8.   5.12V   100%
     I don't get it.
PS - Midnight Tuners Unite :thumbsup:
Sorry for the second post, I forgot to mention this one /|
That's the AFM "correction" table, the actual ramp table (algorithm) for the AFM's is not visible. What you do with the correction table is match an unlisted AFM with one that is listed. You select the closest one in the list to what you are trying to match and then use the correction table to line them up. You do a basic tune of the car with a listed AFM and then fit the unlisted AFM and use the correction table to line up the maps using the map tracer.
Hope that made some sense :)
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
