Yep - that makes sense - Thanks SK.
BTW - You don't happen to know if the above pinouts are correct for the Q45 do you ??
ie:
Flow
=======>Turbo
1 2 3
1 = Ignition (12V)
2= AFM Signal
3 = AFM Ground
Cause when I wire it up like this it doesn't start - (I know it is something to do with the AFM cause the Y31 AFM works) ie I have the AFM wired wrong or it is busted,
Cheers,
  • Replies 43
Yup - getting 12V (ign), 0V (Gnd) and varying volts (signal) from the ECU.
PFC monitor on the AFM setting shows varying volts (1.1 and up , if recall) with the Y31 AFM installed but with the Q45 - I get 0.5V and it doesn't change cause it won't start.
BTW - from memory, my wires are different colours to yours.
From memory - I have (from the ECU)
Orange/Blue - Signal Wire
Black/White - 12V Power
Blue/White - ECU Earth
Which pins are B, D and E on the Q45 ??
Fluting around some more tonight .......
With ignition on only, PFC read out in Monitor reads 540mV when you crank it, it won't start and PFC continues to read 540mV (this is with my Q45 MAF in)
When I take AFM gnd (earth) off the AFM, PFC reads 5100mV and starts, but really really bad idle (which I can understand as the AFM is telling the ECU that I am at max air flow/oxygen density)
When I put the Y31 AFM in - initial AFM reading on the PFC says about ~500mV - when you crank it , PFC reading gradually climbs to 1100-1200 mV and idles fine.
BTW - the Y31 AFM terminals are marked A B C D E F
A= Not used
B= AFM Signal
c= Not used
D= AFM Ground
E= Ignition (12V)
F = Not used
BDE - Chris - maybe this is where you get your BDE from ?? (but not the right pinouts)
I def. don't have BDE or any letters on the Q45 or pins or anywhere.
I still think (hope) that maybe that I have wrong wiring - but don't want to try all combinations in case I blow something up.
OR - the Q45 could be stuffed.
I have searched the web all over the place - and do you think I can find the wiring pinouts for the Q45 ?? Nah - I've even searched on the damn part number of the Q45......
I'm begining to think Z32 is the way to go.......... he he :D
Anyone, Anyone ??
Need to have the car running and tuned by the 27th so I can take it Wakefield and put in a PB.
B-Man,
I may have the info you need. I have the q45 MAF on my car (RB25 in an s14a Silvia Chassis), but it is at home, and I am at work. I am trying to remember, and I believe that the power and ground are reversed from the rb25 MAF (series 2 anyway). I will look when I get home and see what is going on. In the meantime if you want, below is my writeup of how I determeined the correct pinout, so you could do that too if you want.
I couldn't find the info anywhere on the net either and ended up using a voltmeter/ohm-meter to deduce how to hook it up. First, figure out which wire is which from the ECU (I.E. Ground one lead of the ohm-meter on the body of the car/head/block, and touch other lead to the wires from the ECU, the one with Zero ohms is the earth, next switch the ignition on and test for which wire has 5-volts, that is power, the left over one is the signal).
The next part is harder, compare the resistance between the pins on the rb25 MAF to the resistance between the pins of the q45 MAF. I don't remember exactly what the values are, but they roughly similar (I.E. same amount of resistance between the power and earth pins on both MAFS etc). You know what the pins on the rb25 are from the first step. Measure the resistance between the earth pin and signal pin on the 25 AFM, then look for the same reading between two pins on the q45 AFM. When you find the same reading, you know that those are the ground and earth pins, but you don't know which is which. However, you do know now which is the power pin on the q45 (the one that isn't ground or signal), MARK IT!
Now, measure the resistance between the power and signal pins on the rb25 MAF, look for that same resistance between the power pin and one of the two unidentified pins on the q45 MAF. When you have found that, you have found the signal wire. Mark it too. The remaining one is the earth pin.
There you go! Like I said, I think it ends up that the power and earth pins are simply reversed from the rb25, but I don't remember for sure.
Greg Mitchell
P.S. If you can't find similar resistances between pins on the known working MAF and the Q45 MAF, there is a good chance your VH45 MAF is no longer working.
Also sorry about the Americanisms in the post, but that is what I am, and I don't have the time to change them all to Aussie friendly terms, but I did try a little, (earth instead of ground) :thumbsup:
Oh yeah, and typos, I am sure there are some of them mixed in as well. Looks like I also used VH45 and Q45 interchangably, the American version of the President is called called the Q45, so that is where that came from.
I have a Q45 AFM in front of me, it has three pins, they are marked "B D E" above the plug on the body of the AFM. The "B" is closest to the AFM inlet and the "E" closest to the outlet. The plug wiring is as follows;
The white wire goes to B
The black wire goes to D
The red wire (with black stripe) goes to E
The part number is 22680 61U00 A36-000 P60 903F, label is Yellow and this one was made by Jecs (Made in Japan).
I can send you a photo in high res if you need, PM me your email address.
Hi B-Man
I cant help you with the digi pics my camera's were stolen take SK up on his offer cause mine read's the same as his air flow left to right B.D.E. Sorry i cant be of more help
Cheers Peter
Sorry guys,
I've been in Melbourne all week for work. So I haven't done anything.
The P/N on my MAF is 22680 6IU0I A36-000 P61
6Z20A
Nearly the same as SK's excepts for the P60/P61 thing - don't know if that matter.,
Well, if BDE are in the order that SK mentions and BDE are Ign, Sig, Gnd respectvely - the I am wiring it up correctly and I have a stuffed AFM
OR since I have no BDE on the AFM - maybe they are different for the version I have - I'll take a pic
SK - can you please send pic to bfauldsbigpondnetau ? Thanks.....
Greg - I thought about doing it your way - but wsn't sure if the resistances would be similar - I will check that out on the weekend - thanks for the tip ?
I'll let you guys know how I go.
IF anyone has any more info , please post it up - cheers.
Greg Mitchell - you are a farking legend my man........
Measured the resistance betwen gnd and sig/12V on the Y31 AFM - Gnd & Sig = 5.6 Kohms , Gnd and 12V = 12.55 Kohms - between Sig & 12 V = 18.21 K ohms (the sum of 5.6 and 12.55 approx)
Measured resistance between B & D on my Q45 (5.74 Kohms) and then between D & E (12.54 Kohms) and then between B & E (18.09 Kohms)
Therefore I deduced that:
B = Signal (orange/blue)
D = Ground (Blue / White)
E = Ignition 12V (black /white)
Started first pop - lovely ! :D :D ;)
So happy :)
Thanks guys for all your help ! !
Now I need a tune - Chris - mate - send me your maps......;)
Who's the best PFC tuner in Sydney ???????
And for those of you who thought I was making it up when I siad I had no BDE on the AFM - here is the proof (note the BDE in texta , I put that on there - and only works with the above post)
Ignore the I,S,G (in texta) - THIS IS WRONG ! !
Let us know if you experience any strange idle issues.
Steve and I have both had issues due to mesh not being on both sides of the AFM.
Mine used to have a slight idle hunt and slight pop on idle.
The car had problems idling on 600rpm.
With the mesh the tacho needle sits rock solid.
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
