Yeah Joel - I'm getting those already - Hunting a little - (I still have the mesh)
Have tried adjusting the idle control valve on the plenum. And stuffed around a little with the PFC settings - (but I don't really know what I am doing)
If I rev it in neutral all the way to say 4K - then let is go back down to idle, it will stall.
When I bring the revs down gradually , it is OK (won't stall).
I'm pretty sure it is the tune (base map) right now.
How does one compensate for 550cc injectors on the PFC ?? I took a guess and reduced the 'injector' settings down to 80% accross all 6 injectors - seemed to run a bit better after that.
Trying to get a full PFC tune done this week buy someone who knows what they are doing (as oppesed to me)
Cheers,,
  • 10 months later...
  • Replies 43
sorry to dredge this thread up again guys but it's been somewhat helpful in determining my Q45 pinouts.
however it appears from reading all of the replies that B-Man has different pinouts to other people. he found that from left to right (BDE) it was SIG, GND, IGN. this is what i would assume looking at my wiring colours (WHITE, BLACK, RED) in the same order.
however there was a few people beforehand who found that it was IGN, SIG, GND and their cars ran perfectly like this.
can anyone shed some light?
The reason yours didn't have BDE on it because thier are 2 type of Q45 AFM... The Older version of them Don't have BDE. The new version Do.... I think the wiring is the same between the 2 But I had troubles at one point with and older version of a Q45 and Power FC turned out to be a faulty AFM (Q45). Changed to a working z32 - re-wire and worked no problems...
    • It happens, that's what your single stage filler is used for.  If it is still visible after the 3 coats of 2k primer, it will be visible after the paint is laid down.  Its hard to give 100% perfect advice without being there in person, I'm very tempted to say stop where you are, fill your pin holes with a single stage putty first then keep going.
    • New or used transmission? Alignment will be the same with engine running or not. If new, i'm presuming it's a clutch release bearing size issue. If used, are you certain it's a CD009/A and not an older CD008 or less? They had known synchro issues. In my opinion, these transmissions should always be purchased new, they're dirt cheap and you avoid dealing with old revisions.
    • I like your thinking! Looking forward to see how it turns out.
    • You've got yourself a good old game of have fun. That shit is annoying as hell to remove. Thankfully for you, yours is on metal, most of the stuff I take it off is plastic, so typically hear guns are out. I normally end up continually dragging my thumb with pressure over it to get it to peel up. Eucalyptus oil then works well for getting residue and last remnants off.   Edit: plastic scraper might be worth while too. One that'll dig into the foam tape, but not scratch the paint.
    • So I ride and race motorcycles for fun and have always used a van to transport my track weapons. Figured towing a racebike with a skyline would be different and if done right could - "look fully sik" or quite cool for us grown ups lol. Pic of yours truly on two wheels I also have a trailer already kitted out to transport my bikes ...and I have a spare set of rims that match the car that I was going to rebarrel to get deeper dish at some stage but they have just been gathering dust. Sooooooo it is only logical.... Stay tuned !!
