Hey guys,
I 've got a issue with my R33 gtst.
Hoping to get some advice before I start replacing things.
So, randomly, the car will start spluttering, missing. The only thing that seems to fix it is stopping, turning the car off then starting it again and its fine.
It also seems random, I can do the 150km round trip to work and not have an issue.
Yet the other day when it happened, I got out of the car with it spluttering, and noticed plumes of black smoke out of the exhaust, so its obviously running rich.
Turned it off then back on, and it cleared up in a few seconds and was fine.
So, at this stage im thinking AFM. or maybe temp sensor?
So far i've changed spark plugs, air filter, pulled AFM lid off to check the solder joints (all ok).
Cleaned the afm with contact cleaner.
Checked all plugs on loom/sensors.
Nothing has made a difference. Got 50 km into the trip this moring and again, spluttering, anything more than light throttle and it just dies.
Would the 02 sensor affect this? Does the 02 sensor only work below a certain rpm? Tried putting it in 3rd (its auto) and the issue was still there. (so about 3700rpm).
Any ideas?
Cheers
https://www.sau.com.au/forums/topic/455923-trouble-shooting/
AFM and 02 impact the air/fuel ratio. Ie rich or lean.
So do vacuum leaks so check for these also
You have cleaned and checked the AFM.
02 being faulty is a good candidate
Chk engine light does not always come on when these fail.
They can be tested on/off the car. Google Testing 02 Sensor.
Seems it occurs when warmed up.
Oh and a faulty water temp sensor can also cause what you describe
Edited by Sinista32
The random nature of the fault points towards dry joints on the AFM or a bad connection somewhere. Try resoldering the AFM first as it's cheap and easy. (unless you can try a known good one.)
Pulled the lid off and the afm and the joints look good.
I do agree it seems like a bad connection though.
You can't see dry solder joints without a magnifying glass. Remove the old solder and replace it with new, it's usually the pins from the plug that vibrate and crack over time.
So I checked the afm solder joints again, while I was resoldering the pins, I noticed 2 dodgy looking joints on the board itself, re soldered these, put car back together, and wow, it's never ran so smooth!
Just thought I'd reply with how I went, for future searching purposes
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
