Hi all,
I got myself some new brake pads for the rear and went doen to change them today. Got the wheels off, old pads out, and couldn't work out how to get the new ones in... I took the brake fluid cap off and got my mate there to catch any fluid and tried to push in the pistons in with my fingers. No joy. I tried with the old pad (gently) and no joy. Are there any tricks to doing this?
P.S. I couldn't find any tricks or directions other than "push it in" with the search...
https://www.sau.com.au/forums/topic/45597-changing-rear-brake-pads-r33-gts25t/
pushing the pistons with your fingers, good luck. Go down to Autobahn and they have these plates that pushses the pistons back that allow you to put in the new pad. Once you change them with that flush out the brakes because you will have air in them. Thats it.
or just use a spanner or screwdriver, push one side in all the way, then install that sides pad, then push the other side in.. no need to bleed the brakes to change these over!
you might need to bleed them if you didn't close the bleed plug while still pushing on the piston!
try to push the pistons back applying even pressure all the way around it. don't want to score the piston bore. i use a metal plate on the piston, a block of wood on the caliper and a small g-clamp to do the job. just watch the brake fluid resivoir doesnt overflow, but its usually only a problem when changing all 4.
-rb25
i havent needed to bleed my brakes at all since i've had the car.. well only when the fluid got flushed!!
but no you shouldn't need to touch the bleeder valve, just need to use a bit of muscle!!
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that ne side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
    • Very interesting, im not sure how all those complications fit in to running a haltech instead of a stock ecu but I'm starting to think I'm a bit out of my league.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
    • Don't assume the AC relay signal from the ECU is +, some models including Stagea use an earth trigger.
    • Hey good to see you on the forums! Haha Considering this cars past with electronic issues I am leaning towards it being a wiring fault somewhere in the engine bay. When testing the ac relay in the fuse box there was no earth trigger. I am probably going to try "bench test" the compressor by giving it direct ground and power to see if i can hear the ac clutch click otherwise I will be pretty sure I have a dead compressor. If it does work then I will be tracing some wiring it seems.
