For Sale:
1997 Nissan 180sx Type X Midnight purple
Original Midnight purple 180sx with sunroof.
Genuine 129 XXX kms on the black top SR
Motor
-Front mount intercooler (no hole through battery tray)
-Kingugawa Td06 SL2-20g Anti-surge (no more than 3000km)
-Tomei 256 pon Cams
-Tomei Rocker arm stoppers(not installed)
-Sard 850cc injectors
-Walbro 255 fuel pump
-Nistune Ecu
-Turbosmart boost controller
Interior
-Full cams spec roll cage
-Bride Low max drivers seat(can provide original)
-Takata Harness
-Full type X interior(seats,mats,door cards etc)
-Pioneer double din head unit
-Type s alpine speakers in the front
-Jensens in the rear
-Clarion Sub and alpine Amp
Exterior
Oem front bar
Oem Side Skirts
Oem rear pods
Oem front lip
Topstage Roof spoiler
Oem tailights
(all parts are plastic except roof spoiler)
Underneath
-std gearbox(Very healthy)with Os Giken Super Single clutch(5000kms)
-Brand new Fully adjustable front Slideworx coilovers
-Cusco adjustable rear coilovers
-r200 lsd diff re shimmed
-s15 5 stud conversion
-Slotted and dimpled brakes
-Mit performance camber arms
-Mit performance Hicas lock bar
-Slip in subframe collars
-Unknown brand front castor arms
Wheels
Work Miesters Sold
The car was tuned few months ago by Trent at Chequred Tuning making a 250rwkw at 18 psi Very healty car regularly serviced with motul oils.In two years ive put no more than 15000kms on the car as I have a daily.Cars never seen a track day.
Rego till Sept/oct 2015
No rwc(can maybe sort something out)
14,500k with s14 stocks
Located Vic
Msg/Call
0497 599 698
May swap for Track car plus cash my way 180sx s13 r32 r33 cefiro
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
    • STOP GOOGLING FAB9 MAKE BORG WARNER EFR KITS FOR THE NC. THEY PACKAGE AN EFR 6758. DO NOTHING ELSE. CAPS INTENTIONAL. THE BEST RESPONSIVE SETUP EXISTS FOR YOUR CAR, AND HAS BEEN PROVEN FOR QUITE SOME TIME NOW. IN B4 "BUT I WANT EVEN MORE RESPONSE, IN A SIMPLER, MORE RELIABLE PACKAGE" WHICH IS A LS.
