Located - SE Melbourne
Bought these in a pile of parts I bought and are no use to me I've just copied and pasted their description.
All items make me and offer or priced according
A set of steam pipe twin turbo manifolds that suit Nismo GTR turbos
eBay low mount exhaust manifold for std turbo (rb25?)
GTR plenum with vacuum manifold, throttle bodies and IAC bypass valve.
A9976315-FFFE-40F5-90D1-C85CC7C85884_zps
CB138622-D424-46DF-866C-4A7B56D9AA68_zps
32CC3E28-09EA-48BA-B46D-72128399D8A8_zps
BSA wheels 16x6.5 +38 4x114.3
One is lightly buckled tyres are not roadworthy but have a set of other tyres to be fitted.
Price $100
4F881140-4115-4A1D-9B91-30164CFA9296_zps
52E3FA18-BF25-4A1F-B32C-B44E390D2F89_zps
https://www.sau.com.au/forums/topic/456060-vic-rb-parts-bsa-wheels/
Hi there,
I'm after the following if you have any?
- GTR front lip
- GTR wing (must be genuine, 3pc wing. not fibreglass shit, got one alrdy!)
- RB20 coilpack cover. Prefer factory ones but will consider tidy aftermarket ones that cops will take nicely to!
Located south east Victoria, so will require shipping.
  • 2 months later...
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
