http://www.kudosmotorsports.com/catalog/genuine-nissan-pitwork-heater-hose-kit-14piece-nissan-skyline-r32-gtst-gts4-rb20det-p-1598.html
RB25 kit won't fit.
Use this kit from Kudos instead as it will have everything you need. Check it suits your model r32.
Other option is to use Nissan Fast and get the codes for each hose (14) and get them through Nissan which would probably be about the same amount and time consuming.
This took 5 minutes max to search and respond so don't know how it took you a week with no results.
Edited by breaker1845
RB25 kit won't fit.
"these are not the hoses I'm looking for"
The ones i'm talking about are underneath the intake manifold
Id say they would be included in the above mentioned kit
The hoses that connect the hard pipe to the block etc and all the little hoses (for coolant bleed and turbo coolant line) that are under the intake manifold?
They come in the kit
Edited by 89CAL
hey fellas.
been doing bout a weeks worth or research and no turn up.
I'm wondering if the cooling hoses underneath the intake manifold on the RB20 are the same sizes as the RB25, just looking at getting an RB25 kit if they fit.
Cheers.
just head down to enzed and grab a length of heater hose, and cut to suit
Edited by Dan_J
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
    • Pretty sure they run the same engine as the Q50 hybrid which specifies 95 RON.  I ran 98 in mine for a while, but it made no difference in performance or economy, so I have been using 95 for the last few years.  I have never hit 6.0L/100km, but have returned mid to high 6 on the highway.  Being a hybrid, fuel economy is a lot more dependant on how you drive it.  At 110km/h, mine never goes into EV mode on the highway, so returns closer to 7.5L/100. urban driving can return low 8s if you are careful or over 10 if you are a bit more enthusiastic on the throttle.
    • About a quarter of what you want to do. It's only R7R, not R&dismantle&replaceparts&reassemble&R. ? It is stock. I already told you, you will NOT have broken those. It's f**king 4th gear for Christ's sake. You just chipped the teeth off.
