Cool know the black one but wasn't sure about the breather and bov return
Mine has a blitz bov or dump valve close to the throttle plate, is that not standard or bov comes with these cars ?
The return pipe is blanked off so guess it may be it was used and not it no longer it ??
Can you block both of those pipes and remove them ?
Mine has a bov or dump valve on the
https://www.sau.com.au/forums/topic/456079-pipe-name/#findComment-7522816
So does r34 have bov from manufacture ?
If so is it the one just before the throttle plate as mine was changed to blitz
If above is correct thej why do they have the turbo return pipe close to intake which is blocked off? Can one buy a silicone and remove that 2 pipe ( metal ones?)
https://www.sau.com.au/forums/topic/456079-pipe-name/#findComment-7523014
The BOV return needs to be close to the turbo inlet to stop reversion. They blocked it off so the turbo doesn't suck unfiltered air once the atmo BOV was fitted.
Silicone intakes are bloody stupid if that's what you mean, they suck shut when they get hot as the turbo generates a lot of vacuum.
  • Like 1
https://www.sau.com.au/forums/topic/456079-pipe-name/#findComment-7523360
I am failing to understand the point of it
If it is close to intake and the air returns when throttle is closed, the box close to throttle plate releases that air so what is this for ?
Even if air goes there it is trapped, right?
I am sorry if this sounds stupid but don't get it
Curious as to how it works
https://www.sau.com.au/forums/topic/456079-pipe-name/#findComment-7523368
The factory BOV releases trapped pressure in the intake and releases it in front of the turbo so it goes around and around. But this aspect of the functionality doesn't really matter, because the reality of the situation is that the factory BOV is not really a BOV. Calling it a BOV is a lazy shorthand. It is really a compressor bypass valve, and what it does it it opens when the engine is under vacuum to allow air to flow direct from the inlet to the engine without having to pass through the turbo. Thus unloading the turbo and allowing it to spool faster.
Simples.
  • Like 1
https://www.sau.com.au/forums/topic/456079-pipe-name/#findComment-7523503
ok , I have been reading around and know why people are saying to put the original or at least recirculating valve back but i love the sound of the blow off
I know this means richer engine but how much ?
if I want to keep maf , can i relocate maf close to intake or is that silly idea? no one has ever done this and my question would be why not just relocate it ?
sorry if this sounds daft but not sure really
Edited by stranger12
https://www.sau.com.au/forums/topic/456079-pipe-name/#findComment-7526143
    • Im not entirely sure exactly what or where its leaking from, he started to pull the boots to swap to my new tie rods + ends and it just vomited fluid, so he closed em up up, swapped the rod ends to the old rods and let me know so I can figure a solution out, im guessing its all origional as as I passed 103k miles earlier this year im sure its just in need of a full overhual/rebuild anyways.    If i could just yank it off and be good it wouldn't be an issue to ship it out and wait for the turnaround but the guy I work with doesnt really have space to keep my car for a week or two at a time, would rather drop it off and have a replacement ready to drop in
    • What do you mean by "seals"? Internal hydraulic seals (ie, is it leaking PS fluid?) or the rack boots that close the rack onto the tie-rods? Because the former is a rebuild, and the latter is trivial that you or any nearby mechanic could do. Dunno about the cowl. Just buy what you think is required and get anything else you find/break afterwards. Wing? Dunno. Don't like R33s enough to pay attention to them. Mirror glass is just glass (on the surface that you want to polish). Go for it.
    • Hello! Long time lurker, been using the forums to address concerns and questions from afar for a while but I've struggled to find some answers so I guess its about time I made an account and formally asked some more knowledgeable people, since finding local skyline owners is hard (and shops that are knowledgeable or trustworthy to work on 'rare' cars are non existent out where im at, as skylines are quite uncommon to find in the wild around here). So the main 3 questions I have, 1: Steering rack has blown seals, well.. they kind of hold but they are not sealed properly anymore and as my R33 is my DD, i cant exactly rip the rack out and send it off or attempt to fix myself. As most refurb ones are around $1,100 or more shipped, and I have other things I need to work on around the car, I was seeking clarification on whether an S15 rack will more or less bolt right in, and whether a common mechanic could do any other required work to get it to fit. I ask, as I've found a supplier than can sell a manufactured as oem one for around 400, if not I'll likely order a used one from Jacks JDM, and take a risk on the seals there. The second question i have is that im replacing the front wiper cowl and have planned to buy 4 new clips and a new center clip but wasnt sure if there were any other clips that would also need to get replaced while I was at it. Given im sure any that are there now will simply break when I remove the old cowl... Last thing would be a fairly straight forward question, i think. If I manage (strong if, finding one has proven to be a pain) to find a R33 GTR spoiler/wing will it require much modification to bolt to a S2 R33 GTST? I've read the bolt patterns dont match but otherwise would bolt in, only options I have found with much luck is China stuff on ebay and carbonetics, which has a nice $650 shipping fee... so if anyone has any pointers where a US chap could locate one that would be great Random side question as well, the mirrors as I understand are mirror glass, and as im planning to polish my windows from water spots and surface scratches, i was hopeful cerium oxide would be fine for them too, as my research points to, but clarification is always nice. Any pointers would be appreciated, and while I have scoured the internet for answers if I missed a prior post somewhere that may answer these directly please point me towards it, as i must have simply missed it. I have seen a post here or there that has mentioned it, but I usually get 50-50 answers, or half answers... I dont have a lot of fab experience or mechanic experience, outside of hydraulic and pneumatic stuff I did in the military and with how hard it is to source stuff in the US, id rather not wing it and hemmoraghe money lol. Thanks guys! Sorry for the monumental first post haha
    • Yep, there's a very minor drift left that happens a few seconds after letting go of the steering wheel, but not enough to bother me. Enjoying the car still!
    • Got you mate. Check your email!
