halogen lights?
Only reason I started replacing hoses was I went for a short drive to the shop the other day and finished shopping and started the car and started to drive off and could see a big trail of fuel in the rear view mirror. Parked up and found the bottom hose to the fuel filter had busted. Lucky I was near a car part store and was able to get a replacement hose and back on the road. But got me thinking I had owned that car for around 20 years and was all original fuel hoses so probably time to replace all of the fuel hoses. Was pretty lucky it went where it did.
A few kg falling from a few feet is enough to move parts of your skull inwards into your brain Also, there's always news about people getting crushed, and occasionally killed, working under cars Be safe is your endeavours
I was just going to replace the fuel line and keep the stock one, but they do look pretty nice lol.
Are you going to delete the stock damper or are you just replacing the fuel lines and keeping the stock damper? There are also options for sexy ones if the stock one is too ugly for you lol - https://www.radiumauto.com/Fuel-Pulse-Damper-Inline-Kits-P751.aspx or https://www.radiumauto.com/Fuel-Pulse-Damper-Direct-Mount-Kits-P759.aspx So sexy. -
I think you guys are right. The only reason I thought it was a restrictor was I had seen the same yellow band on the r32 boost restrictor. Will just replace with a standard fuel hose. Thank you for your speedy replies. I'm sure I'll have many other silly questions.
