  • 4 weeks later...
Just a few updates.
Went to get it tuned to get it to run better and found out it had a leak from the gasket on the intake manifold.
And because this used to run gas i had blocked up the holes on the runners that the gas was injected into. So while i had the inlet mani off etc i thought id replace it with one without holes.
What a shitty job it is to do! But all done and will go in for a tune again this week sometime
Also replaced my front seats with GTR ones.
Looking for some rear seats in good nic if anyone has any
bought a 32 GTR spoiler and boot to put on....
Got the car tuned, dyno sheet below.
Still having a problem with the car ummm, cutting out and hesitating then like bunny hopping and wont rev. Tuner thinks either the AFM or the crank angle sensor.
Will find an AFM asap and try that. easiest thing to try
  • 1 month later...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
