Hey all,
“2003 Motor Trend Car of the Year” – Infiniti G35 PREMIUM Model ONLY 50,000 kms. $18,500 NEG.
Lowest Kms in VIC of 50,300 Kms! This car has been freshly imported and never been driven in Australia!
6 Speed MANUAL 2003 Nissan Skyline V35 350GT - “Infiniti G35” – 206kW 3.5L V6
Practically a Brand New Car and Even Smells like a New Car!! As seen in the photos, it is in pristine condition both inside and outside.
Road Worthy Certificate (RWC), Complete Import Paperwork and all original log books and owner’s manuals showing genuine mileage will be provided.
This is the PREMIUM G35 model which has several upgrades over the standard 350gt model including:
- Leather Seats (front and back)
- DVD Player and Sat. Nav GPS with 7 inch pop up screen
- Dual Climate Control
- BOSE 225 Watt Audio Surround System – Sub under seat
- Heated Seats
- Driver and Passenger Seat Memory
- Bluetooth
- 6 Stack CD Player
- Sports Tuned Suspension
- Snow Traction and Power Switches
As it shares the same drivetrain and Engine as the Nissan 350Z, servicing is cheap as all mechanical parts are interchangeable with the 350Z.
A minor service conducted on arrival in Australia including: New air, fuel and oil filters, wiper blades replaced, brake fluid flushed and replaced, fully steamed cleaned interior, child restraints modified and more. The car is now fully complied to meet Australian Standards and ready to Drive Away!
Other Features include:
- Lowest kms in VIC and paperwork to show mileage is genuine!
- Brembo Brakes
- Hornet Aftermarket Immobiliser (plus factory immobiliser)
- Nismo Dual Exhaust provides a beautiful quiet note
- HID Xenon Headlights
- 18inch wheels
- Back Windows Tinted in Darkest Legal, Privacy Tint
- Genuine G35 Floor mats (photos to come)
- All 3 original G35 keys and USB
- Rear View Camera
- Cruise Control
- Folding Mirrors
- Tilted Side View mirrors for reversing (avoid gutter rash)
- Remote Boot Opening
- 6 way power seats
- Front, Side and Curtain Airbags
Available most days including during working hours, after hours and weekends for inspection.
Price NEG.
Anthony 0432 699 241
https://www.sau.com.au/forums/topic/456119-2003-nissan-skyline-v35-350gt/
PRICE DROP ~ $17,900
Forgot to mention:
I imported this myself and was going to keep it as my personal car but since we are looking to have kids soon it's probably not that child friendly :( This car has been freshly imported and never been driven in Australia and you will be the 1st lucky owner!
  • 3 weeks later...
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
