Hey!
I have recently purchased my first R32 skyline and I've looked through the cosmetic threads and had a really good read. There is a lot of awesome tutorials.
What I didn't find was cosmetic modifications that can be done on a budget!
For example when I owned and R31 A popular budget mod was to paint the door Centre pillars black.
Does anyone have any good suggestions for some budget mods?
Thanks
Edited by Fernkeeper
https://www.sau.com.au/forums/topic/456128-low-budget-cosmetic-mods/
Steve, if it's only the cost of a spray can you can afford. You probably shouldn't have bought a 25yo Skyline
But as per your question here are some suggestions
Paint the rear view mirror and cabin centre light in black - looks good
Also remove the faded or peeling material from the doors and rear cabin and paint them in black.
Remove the rear wiper and put a flat rubber plug in it.
You could remove the glass lenses from your headlights (oven method) and paint the non reflecting parts black.
Change the triple gauge and cluster lights to LED's
Personally I'd give it a full service for starters and work on things like brakes, steering & suspension
Edited by Sinista32
Thanks for your reply! My initial question seems I have implied I can only afford a spray can, that's not the case. I ask for small budget mods like the ones you have mentioned as I have done all the suspension and brakes and in the process of saving up for some engine mods. I wanted some little things to do in in betweeN saving.
Cheers for your ideas!
I wasn't sure whether or not to retrim the c pillars or like you said remove the trim and paint them black.
Re-trim the C-pillars as you can fold it under
How ever re-trimming the centre of the door cards is only temporary as they will lift on the extremities eventually due to the way the door card is originally pressed
Take apart your headlights, paint the surrounds black. While you're at it, retrofit some HID projectors, the standard R32 lights are shithouse and dangerous.
Not only will your headlights look cool, but your night vision will be vastly improved. Plus you can have HID wars with the OEM equipped cars (and laugh at the noobs with 8000K shitkitted lights).
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
    • Did the noise appear after your sand trap adventure? Could be something got dislodged and is playing rub rub. Even a rock wedged somewhere.
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
