Fellow sau members
My car has a million problems need help solving one my old r33 did the same I just sold the thing without fixing it this one does it all the time
Problem
When the cars hot after a while I don't mean running temp more like drive for half an hour. My car seems to all of a sudden loose power after a quarter throttle
Things I noticed are the exhaust note hangs sounds like the car is struggling (which it is) it sounds like it's slowly revving out but takes forever
Natural instinct makes me back off but if I keep the throttle down it really goes nowhere!
Since I have been swamped with other things it's been put off for a while until I get the cars other issues fixed
It's really annoying and I can't overtake anyone with the power of a charade
While I'm writing a thread does anyone know why it idles high? 1100 rpm.
Thanks in advance
https://www.sau.com.au/forums/topic/456157-problem-when-cars-warm-rb20det/
Yeah I'll just replace is. Is this in reference to my idle issue or nugget when hot issue
(Please note that my thermostat is new and the car gets up to "running temperature" quickly it's drives longer then say 30 minutes sometimes longer before it does it.
(It is accumulative so if I do a lot of short trips it still does it)
Both - Idle and Nugget
Edit: Basically the ECTS (Water coolant Sensor) is sending poor info to the ECU which is getting info from other sensors as well.
By the way it should cost around $40-50 and you can change it yourself
Edited by Sinista32
20+ years old car now man, things start to get old/worn/brittle. Start slowly gathering parts and replace them (e.g. coilpacks + harness + from performance-wise, throw new BCPR6ES-11 spark plugs in as well).
Having a standard engine is a bonus, less shit to worry about when diagnosing.
I miss my black GTS-t :(
The larger the gap the better/bigger the spark therefore better the burn :)
With a stock car running average boost your best off with 1.1mm on your spark plugs.
When you modify and wind up the wick wait until you get issues prior to reducing the gap down.
There wont be any issues running a smaller gap with new splitfires BUT it's not optimum. See first line ^^
Edited by Sinista32
Cheers sinista sounds like a plan I'll give them a shot
And cheers got that jiffo
I'm not the smartest with a multimeter so how exactly do I set it up to measure the ohms and I'm obviously unplugging the sensor correct?
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
