Good morning fellows
Car is 1997 Stagea 208000 ODO km's more likely 300000 km's
Over the last year my car has been starting weird but i put it down to a sticky starter solenoid, i turn the key to start it would take a few on and offs or just hold it in start and after a few or 10-15 seconds it would fire.
Last week the starter began struggling to start the car, it had a VL RB30 one in it that was cheap (now 100000km's old) so i chucked i second hand RB25 one in it and still had the same problems. A new battery seems to have fixed the starting problems as it now starts consistently strongly all the time (but still with the pause of varying seconds before it fires).
Now i'm having a problem where the power will cut out while driving first to the stereo and clock. Intermittently it will run rough, the clock goes dim, stereo goes off and comes back on again without either resetting their presets. I can make the stereo and clock happen regularly by driving around and turning my headlights on and off, after about 10 times the stereo cuts out as i think that's the first thing to respond to the drop in power. The rough running and engine shutting down i cant replicate just the clock and stereo.
After going round the block doing this i went to lock the car with the remote central locking and it wouldn't so chucked the key in the ignition and no power, took the battery leads off to inspect and put them back on and back to normal power and strong start.
The battery is new so tests fine with the multi meter at 12.9 Volts
Alternator tests at 13.8 - 13.9 with running so going by google that is fairly normal
There is a small crack up to half way in the negative terminal clamp for the battery unsure if significant? i wrapped it in foil to cover the crack (LOL) and it has made no difference
I was thinking it could be the ignition barrel as i'm driving when the engine cuts out, the stereo cuts out along with the digital clock in the middle of the dash. All the accessory lights are then on obviously because the engine has shut off and the key is still sitting in accessory. The only reason i doubt this is the power cutting out while the car is stationary and off, also if i jiggle the key (fairly violently) when it's running i cant get it to do anything.
I did the timing belt & water pump 2000k's ago and when it's running normally it runs great, smooth, good power etc (intermittent miss at idle never been a problem though?). I have no idea when it comes to electrics so hopefully someone here can point out my stupidity or it's auto leccy and ass rapage time!
Thanks in advance
    • Hi, is the HKS  Tower Bar still available ? negotiable ? 馃
    • From there, it is really just test and assemble. Plug the adapter cables from the unit into the back of the screen, then the other side to the car harness. Don't forget all the other plugs too! Run the cables behind the unit and screw it back into place (4 screws) and you should now have 3 cables to run from the top screen to the android unit. I ran them along the DS of the other AV units in the gap between their backets and the console, and used some corrugated tubing on the sharp edges of the bracket so the wires were safe. Plug the centre console and lower screen in temporarily and turn the car to ACC, the AV should fire up as normal. Hold the back button for 3 sec and Android should appear on the top screen. You need to set the input to Aux for audio (more on that later). I put the unit under the AC duct in the centre console, with the wifi antenna on top of the AC duct near the shifter, the bluetooth antenna on the AC duct under the centre console The GPS unit on top of the DS to AC duct; they all seem to work OK there are are out of the way. Neat cable routing is a pain. For the drive recorder I mounted it near the rear view mirror and run the cable in the headlining, across the a pillar and then down the inside of the a pillar seal to the DS lower dash. From there it goes across and to one USB input for the unit. The second USB input is attached to the ECUtec OBD dongle and the 3rd goes to the USB bulkhead connected I added in the centre console. This is how the centre console looks "tidied" up Note I didn't install the provided speaker, didn't use the 2.5mm IPod in line or the piggyback loom for the Ipod or change any DIP switches; they seem to only be required if you need to use the Ipod input rather than the AUX input. That's it, install done, I'll follow up with a separate post on how the unit works, but in summary it retains all factory functions and inputs (so I still use my phone to the car for calls), reverse still works like factory etc.
    • Place the new daughterboard in the case and mount it using the 3 small black rivets provided, and reconnect the 3 factory ribbon cables to the new board Then, use the 3 piggyback cables from the daughterboard into the factory board on top (there are stand offs in the case to keep them apart. and remember to reconnect the antenna and rear cover fan wires. 1 screw to hold the motherboard in place. Before closing the case, make a hole in the sticker covering a hole in the case and run the cable for the android unit into the plug there. The video forgot this step, so did I, so will you probably. Then redo the 4 screws on back, 2 each top and bottom, 3 each side and put the 2 brackets back on.....all ready to go and not that tricky really.
    • Onto the android unit. You need to remove the top screen because there is a daughterboard to put inside the case. Each side vent pops out from clips; start at the bottom and carefully remove upwards (use a trim remover tool to avoid breaking anything). Then the lower screen and controls come out, 4 screws, a couple of clips (including 3 flimsy ones at the top) and 3 plugs on the rear. Then the upper screen, 4 screws and a bunch of plugs and she is out. From there, remove the mounting brackets (2 screws each), 4 screws on the rear, 2 screws top and bottom and 3 screws holding in the small plates on each side. When you remove the back cover (tight fit), watch out for the power cable for the fan, I removed it so I could put the back aside. The mainboard is held in by 1 screw in the middle, 1 aerial at the top and 3 ribbon cables. If you've ever done any laptop stuff the ribbon cables are OK to work with, just pop up the retainer and they slide out. If you are not familiar just grab a 12 year old from an iphone factory, they will know how it works The case should now look like this:
    • Switching the console was tricky. First there were 6 screws to remove, and also the little adapter loom and its screws had to come out. Also don't forget to remove the 2 screws holding the central locking receiver. Then there are 4 clips on either side....these were very tight in this case and needed careful persuading with a long flat screw driver....some force required but not enough to break them...this was probably the fiddliest part of the whole job. In my case I needed both the wiring loom and the central locking receiver module to swap across to the new one. That was it for the console, so "assembly is the reverse of disassembly"
