Hi guys I am a bit of a newb with turbo set ups and have just brought my first turbo powered car a S1 R33!
At the moment I am running a turbo smart boost controller with the stock gauge that does not seem to be very accurate and only reads up to 7psi.
I would really like to upgrade this and I am trying to work out weather to get a gauge and stay with my turbo smart mechanical controller or to go the electronic one, so I am looking at for and against's. Am I right in assuming that with the electronic controller I can adjust the amount of boost and it will tell me how much boost I am running?
Also as far as fitment is concerned I would like to have a go at fitting it myself and I was wondering if the electronic one would be fairly straight forward for me to hook up or would I have to pay someone to do it? I do have basic mechanical knowledge with motorbikes ect but not real good with electronics.
Thanks
Andy
Congrats on getting a skyline, they are a good fun car and fairly easy to work on, alot of cheap parts around for them too. There's tons of threads already with good info on what you've asked, best to do some searching and narrow down your q's first.
it actually is pretty accurate, however the scaling is in torr - which people have no understanding about.
http://en.wikipedia.org/wiki/Torr
Stock gauge is in mmHg x100 from -7 to +7, not psi for a start. Which if you do the conversion is about up to 14 psi (not quite) at +7.
There is heaps of information on electronic and mechanical boost controllers and you should read up on how each works, the benefits and how it would suit your cars setup and what you plan to do in the future. There are many combinations but not all will suit what you want so picking the ideal one could take some time before even purchasing the item.
Setting up a boost controller is fairly easy and there are heaps of topics on this also, but if you know f**k all about electronics or anything mechanical it could take you a long time or you will get something wrong. So take the time to learn and research and make sure its running right before boosting your car and possibly free boosting it, lol.
If you have only just got the car it might be a good idea to do a full service on it if you haven't already starting with fluids, belts and anything that could be a problem while researching boost controllers.
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
