Slides up and a little towards the hole. They can be a little tight though...
Easier when the fuel level is low and you can get a torch in there to see how it works.
I only have a lighter, that should work;
Right?
  • Like 2
Right?
i know this is bad. But i had to do this to check the pump and fittings while it was out of the tank. Old girl let out in a dark alley and my phone went dead.
Everything went better than expected, was home by 2am haha
grate the car god's can to help me, GOT IT OUT after 2 day's I did bend out the clip on the day 1 but no luck on day 2 I got the biggest pair of pliers on to the side of the cradle & pulled it up & out what bitch of a job. Thank you all for all of the reply's .
Wait til you try getting it back in; that's the fun part
Also, how good is that feeling when you finally arrive home circa midnight after a long night of working on a car? Drive home is the sweetest, especially if you're enjoying the fix/modification you just made.
Or better yet, the sock is around the wrong way. So your fun drive home turns into a stop start drive home.
  • Like 1
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
    • I dunno what the "best" one is....but when my 040 died late last year, after about 20 years of screaming service....I put in a 255. Like any such thing, you have to finagle it a little bit - it's not a no-brain swap. But it's not hard.
