I like something around 500bhp from fly which i think would be around 400 at wheel, right ? CONVERSION IS EASILY SEARCHABLE
I don't want to go forge or change cams at this stage . SEARCHABLE TO SEE WHAT STOCK ENGINE CAN DO
I have seen gt35,30,28 and number of others but not sure what is best for me . NO ONE DOES EXCEPT YOU, I SAY GT3076
everyone has a different opinion reading around . what would you get and what is the max power from the turbo at what psi ? WHOLE THREADS ON TURBO RESULTS = SEARCHABLE
I think gt30 is low mount which is good but gt35 or other are high mount and if i was to run gt 35 , I think it will be very lazy as I will be running it at a very low boost , right ? VERY SEARCHABLE TO SEE TYPICAL RESULTS FROM THIS TURBIZZLE
I think minimum mod to get to 500 bhp is :
550 or above injectors
bigger intercooler
ecu ( link 4)
turbo . PLENTY OF SEARCHABLE ON WHAT MODS NEEDED FOR POWER LEVLES - FUEL ECU ETC
and possibly manifold if it is not straight bolt on as most people say gt30 is .
am i right ?can i expect safe 500bhp from the car with the above cost and mod ? THIS ONE COULD BE DISCUSSABLE, ONCE YOU HAVE DECIDED ON A SETUP
if I was to do this in stages and buy the turbo and do no remap but run it at low boost , will it work ? ANY TURBO CAN BE RUN AT LOW/ZERO BOOST...BUT NO ONE WOULD, THEY'D WANT TO CAIN IT, HUMAN NATURE
dude I'm all in favour of helping those that need it, but those that don't help themselves I'm not so keen on. I've made some notes above to assist you in your quest. I'd advise do some more research, decide on a setup that will work for your goals and budget, then put it forward for discussion and for people to make recommendations on. Just asking for info to be broadly given to you really pisses ppl off, gets you less genuine replies, and ties up the forums on here.
Some of my questions as said was for confirmation of what was read
But cool mate no more replies will work it out.
What annoys other is thinking i am lazy and I can't be as i want to do it all or most diy and you can't fo it unless you know what you are doing
But then u need help everyone now and then which most people on this forum are brilliant at giving apart from few odd one
Welcome to the friendly skyline club, I'm sure you want to become a paying member now. This used to be a good place for help once but seems all the older crew have moved on.
You should help him . you know, so he stays.
Give a man a turbo he turbos for a day.
Teach a man to turbo he turbos for a lifetime.
Boost on brother.
This forum has the knowledge, but the same questions get asked all the time and they are the most entry level questions imaginable, if you have serious questions that cant be answered by a simple google they come and ask.
but you really need to apply building your own knowledge first by learning and yes it may not be the quick way but it is the only way to really understand what it is your trying to do...
I have mate don't know why some don't get it
So many choices wanted to get further views but of course all posts are currently joke
You already have too many choices and you want MORE opinions??? Lol. Sorry mate. Opinions are like arseholes, everyone's got one. The signal to noise isn't going to be any better if you ask the same old question again.
Honestly, do your research. Form your own opinion, and go with it. The decision will be yours, it will be based on the information available and you can justify the choice to yourself. And it will be a better decision than "some random dude on the internet said it was good" because you know what you want and you put the thought into it yourself.
I can't count how many times I've spent 5 hours trawling forums for info. It happens. When it gets a bit much, make a spreadsheet of the important factors to you. Or there's another tactic, Say you have 4 items to choose from. Pick two at random and pick the better one out of those two. Don't hesitate, just pick one. Right. Now look at the other two. Pick one. The two winners - put them together. Pick one. That's your final choice. Once you've done all the research you just need to trust your gut instinct.
we are friendly, we haven't told him to neck himself yet :)
well you see, most of the smart arse replies are actually from the older crew..
ok let's play nice kids..
OP, what power do you want? and at what RPM do you want to hit your targeted boost? and the final question.. how much money do you want to blow?
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
