The new NSX is almost upon us and it looks incredible.
Its a hybrid with a twin-turbo 3.5 litre V6 and a dry sump. As with the original GTR and NSX, this one looks much more "supercar" than the R35. Especially with its transparent engine cover.
The profile and rear look like a cross between a McLaren and a new Corvette.
The Acura model is being built in North America. I'm hoping that the model we get is built in Japan.
Basic details and a guess of $150k shelf price available on Road and Track.
I've included a pic of the NSX concept from 2012 which looks remarkably like the final product.
Check out the micro site on Honda.com.au to register your interest.
And, the concept;
What do you think?
  • Like 1
https://www.sau.com.au/forums/topic/456227-2016-honda-acura-nsx/
Wonder what it means for the next gtr? Hybrid too?
Nissan has all but confirmed that the next GTR will be a hybrid. http://m.drive.com.au/motor-news/2015-nissan-gtr-hybrid-confirmed-20131108-2x5wh.html
Most of the Prelude Australia guys (of which there aren't many left), think it's horrid.
I guess they're thinking this is too far removed from any Honda sports car appearance of former years.
At least Carlos Ghosn insisted on the afterburner lights on the R35 and from the side, the front end has the same bonnet shape as the R33.
I like the idea that the future R36 will be pared down to 14**Kg.
Back on thread, this new NSX/Acura could badged as a Veloster Turbo and I'd believe them. And that's despite the fact that I like Honda engineering...
  • Like 1
The meeting, they look like they're trying to go Lamborghini-ish with their styling.
Trying to get into supercar territory.
I don't mind it, but for the price(let's face it, it's going to be very exxy) I'd possibly look at said lambo.
I think Honda haven't made another future classic here, it will be a car that just fades into the past due to it's extremely generic look. They just bowed to the norm of aerodynamics today and threw out most traces of the past. There will always be the Honda fanboys loving it though.
When the new GTR was first shown off why did everyone get so horned up over it and why has it been so successful?
I don't mind the look of it, and I reckon it will be a decent performer (but then again I'm a Honda fanboi)
The biggest problem as I see it is that the original NSX was such a surprise when it hit the market - nobody expected the levels of performance from it. That's probably the main reason it's gained the level of notoriety / status it has. Now that the element of surprise is gone, everybody is expecting another giant killer. If it achieves this, then it's a case of "yeh, so what"? If it doesn't deliver giant killing performance, then it will be remembered as a dud.
Not an easy task.
  • Like 1
^Yup. It's like trying to follow up a killer debut album. The original NSX is the Appetite for Destruction of the motoring world. My biggest fear is the new NSX is the "Axl Rose world tour" of the motoring world.
  • Like 1
    • Are those 1000cc side feeds? If so, that's part of your problem. I have 1480cc and they idle at stoich on 98RON, and all the way to E85. Also your coil packs.....
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
    • 300hp (225kw) is barely outside the standard turbo's range with a bit of extra boost in it (200ish). If you are going to change the turbo you should aim for 250-300kw (330-400hp) to make the expense worthwhile
