Just in Qld at the moment... Have spoken to this guy at a workshop about aftermarket turbo's... Aparently ball bearing turbo's have a very limited life span (in some cases like 10,000km) and easily stuff up. I was told it is a better option to buy a non ball bearing turbo as it will last??? Any other views about this???
https://www.sau.com.au/forums/topic/45623-ball-bearing-turbos/
I suggest you find another workshop URGENTLY.
Run as fast as you can away from that one, and do not look back over your shoulder !
I bet he just happened to have a crappy old turbo off a diesel farm tractor that has been fully reconditioned, for sale, a real bargain too.
Did he also tell you it would be absolutely perfect for your engine ?
Run for your life.......Hehehe
Coxy, cost of repair is not really an issue.
You could use wooden wheels off an old stage coach on your car. They would be far better, because the narrow steel rim cannot get a puncture. This would save you the cost of repairing punctures.
Seriously though......
Do not be fooled by certain "advantages". Turbo technology has advanced hugely over the last thirty five years. Using the old stuff just because it is cheap is not an advantage if you can afford something better.
The modern turbos are far more durable in every way, with the notable exception of ceramic turbine wheels. The water cooled ball bearing units are far tougher. If you replaced both wheels, housing, bearings and seals, and balance it, I doubt if a whole new ball bearing centre will cost any more than a whole new sleeve bearing centre.
Cool- Im looking to get a new turbo for my car soon and I was speaking to a mate of mine who works with turbos all the time and the ball bearing ones (unless there's a problem with it of course) will last longer but the cost to replace a core for the one im looking at is about $1800- the same sort of turbo but with a bush core id be looking at around 3-4 hunge..
What sort of turbo would you recommend suit a 34 to run a safe 16psi?
I dont go to this workshop, the guy is a mates mate... This is what i was told. He said this to me in order to back up his statement "why do all drag car's run non ball-bearing turbos, except the HKS drag GTR which changes its turbo's every meeting, because their life span is only like 1.5 meetings"... What do you guys think?
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
