I've been a member here for many years, but have never actively participated. As I'm now seriously considering a GTR purchase, I figured I should share some of my images and contribute.
These are some images I took for fun at a family property in Goulburn earlier this year - follow the link to my Flickr page for some of my motorsport content:
18642830090_8c52e49c83_c.jpgMilky Way - Windellema NSW by Stefan Trajkovski, on Flickr
16979313027_05394305df_c.jpgEaster 2015 by Stefan Trajkovski, on Flickr
16999211710_4a40f03427_c.jpgEaster 2015 by Stefan Trajkovski, on Flickr
16998988618_593a0b8985_c.jpgEaster 2015 by Stefan Trajkovski, on Flickr
17186717955_9f43f0cb3a_c.jpgEaster 2015 by Stefan Trajkovski, on Flickr
17092403772_7e5e7a43a0_c.jpgEaster 2015 by Stefan Trajkovski, on Flickr
16906130008_4c9040cb9a_c.jpgEaster 2015 by Stefan Trajkovski, on Flickr
16907682539_7407aec84b_c.jpgEaster 2015 by Stefan Trajkovski, on Flickr
17067934586_c7c8883ba4_c.jpgEaster 2015 by Stefan Trajkovski, on Flickr
  • Like 2
  • 1 month later...
  • 3 weeks later...
  • 2 months later...
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
