Hey guys sure this gets asked all the time, but my much loved 1996 r33 gtst after nearly 250'000 kms (imported at 77'000) and 9 years of ownership has finaly said no more!
Developed a bottom end knock about a month ago, limped it to and from work as I had no other option!
removed and striped down my motor, found a near dead clutch, swolen and hard coolant lines, rear/front mains starting to weap,
Improved 2 piece turbo side engine mount :rolleyes: lol,
And then i got to the striping, Piston 5 big end bearing destroyed, metal all through the motor, bits stuck on other
bearings, bits in the oil pump, the oil pumps drive collar worn, as the same as the oil pump.
Oh and a cracked exhaust housing of my OP6 highflow.
The good, piston rings and bores are great for their age, valve train and head is mint.
So whats next? should i go with new seals, bearings, oil pump, piston rings, repair the crank oil pump drive? and obviousaly the external broken parts and be done with it?
Or should i source a second hand much lower km r33 rb25det?
or r34 rb25det neo and do a conversion? if so should i use a full loom and r34ecu? or bits and pieces of r33 and r34 electrics?
Or the most expensive option, get my bottom end built and forged?
Just after some advice here as im not exactly sure what path to follow, keeping in mind i want to keep this build as cheap as possible,
I was very happy with the responsive 221rwkw and 380nm it had for a solid 3 years before the bearing let go
Thanks for any advice given!
Cheers, Rob D.
power does not concern me, but to have my 33 reliable for another 5 years or so would be sweet, with the neo, did you do a whole conversion with ecu and loom or a long motor swap out with 33 electrics?
Not worth mucking around to put the neo in if you don't plan on wringing its neck to be honest. Easiest/cheapest option is buying another standard RB25 bare engine and putting all your bolt on on it and putting it back in the car. You can make some money back by selling your good condition head.
    • I believe Unimog is the only vehicle that has it (from the manufacturer). I haven't seen aftermarket permanently connected kits, but I haven't looked either.
    • Ha ha ha, can't overthink when exhausted... Oh how I wish I had that power! I can be absolutely dead set shot, and my brain will still go "we need a good 3 or 4 hours to just think about everything and anything before you may sleep... My biggest thing is making sure I give myself enough sleep. I don't operate on even 7 hours of sleep! I attempt to give my body 9.5hours sleep a night to be able to function. I don't sleep the whole 9.5, but I need to make sure I offer a big window. I also take a single supplement, which is to help with long term health, and fighting inflammation, and I notice it helps massively. Especially me sleeping, and just less "achey" in the body. Have also kicked sugar, and gluten. A majority of people with ADHD don't go well with gluten. It causes a really interesting natural opioid overdose in the brain, which causes bodily issues and sensory issues.
    • Yeah that's what I meant, permanently connected not manual
    • Yep. But typically that's just run a hose down to the tyre while stationary.   Oh and the Unimog will automatically air up and air down tyres from the onboard computer for you too.
    • There was a good video somewhere, maybe Kurzgesagt that linked physical activity to ADHD/Anxiety/Insomnia etc. Basically the body WILL spend energy doing something if you don't spend it doing anything physical. It isn't fun, but I personally have noticed I've never been overthinky, or unable to sleep if I'm physically exhausted from doing a lot. The musings around it seem to indicate that this is one of the reasons/mechanism that physical activity improves mental health/wellbeing etc, by more or less not using that 'extra' energy to overthink, be anxious, inflammation, etc. There's also the fact that every obnoxious exerciser ever says it's great and helps which is extremely annoying. Like people who say the same thing about travel being the best thing ever. I mean, they clearly are, but blah. I started doing a LITTLE myself (think 3x15min per week) and honestly did notice the benefits, aiming at life quality when older. Which is sooner than you think. Getting something into your routine that you can actually make a routine has helped me at least. This post brought to you by procrastination between sets.
