Hey guys
I have a leak in the gasket coming from the exhaust or dump pipe - does anyone know a cheap place to get this fixed? Anywhere in Sydney and how much roughly does it cost to get the gasket fixed? I'm pretty sure it's the dump pipe gasket.
Thank you
    • Kaizo Industries put a VIN plate over where the Nissan plate would go. It was part of how they broke the law and attracted feds going after them.
