Results for 14 Skyline Aus - Adults at 10:24
Heat overview Best time
1. Desmond Ong 00:36.162
2. Anton Polkamp 00:36.258
3. Michael Hill 00:36.588
4. Eric Yamashita 00:36.596
5. Matt Ware 00:36.703
6. Ian Blott 00:36.829
7. David Milano 00:36.837
8. Brennan James 00:36.877
9. Dale Laughton 00:36.977
10. Alex Bennett 00:36.986
11. Peter Savva 00:37.098
12. Rajeel Deo 00:37.164
13. Rajeev Deo 00:37.844
14. Mathew Leal 00:39.032
15. Jun Ma 00:40.142
  • Like 1
Lol gokarting iz srs bizness.
Had heaps of fun, they do seem a little erratic on black flagging;
I punted a slowing kart at the top of the track early in the 3 session, and put my hand up when the Marshall chick pulled out the black flag.
She then flagged the driver in front, and on the same lap pinged someone else, even though again I had my hand raised.
I think on the next lap she did someone else.
So if that was you, sorry.
Results for 16 Skyline Aus - Adults at 10:48
1. David Milano 00:36.207
2. Anton Polkamp 00:36.248
3. Michael Hill 00:36.405
4. Ian Blott 00:36.432
5. Eric Yamashita 00:36.468
6. Dale Laughton 00:36.519
7. Desmond Ong 00:36.562
8. Peter Savva 00:36.610
9. Mathew Leal 00:36.696
10. Matt Ware 00:36.713
11. Brennan James 00:36.865
12. Alex Bennett 00:36.954
13. Vince Aquino 00:37.308
14. RD Borbajo 00:37.758
15. Jun Ma 00:38.875
Luddenham Raceway
821-849 Luddenham Rd
Luddenham NSW 2745
http://www.luddenhamraceway.com/
  • Like 1
Best times of the day
1. Christopher Refalo 00:35.983
2. Desmond Ong 00:36.162
3. David Milano 00:36.207
4. Anton Polkamp 00:36.248
5. Paul Savvinos 00:36.263
6. Dylan Braithwaite 00:36.265
7. James Wen 00:36.397
8. Michael Hill 00:36.405
9. Ian Blott 00:36.432
10. Eric Yamashita 00:36.468
11. Dale Laughton 00:36.519
12. Robbie Thomas 00:36.590
13. Peter Savva 00:36.610
14. Jesse Mcdade' bates 00:36.619
I really need to get back on the forums. I missed this and i live 5 min away :(
Duuuuuuude! at least subscribe to the Events section!!! Email alerts so you don't miss that shit!
Also, would be interested to know how heavy the karts are to see if the weight increase is actally negligible or not :P
Hehehe.
Desmond pulled a blinder in the last session; well played good sir!
Hehehe second session really. Had a clear track for 2 laps. I need to lose weight. 85kg 4 stroke karts makes me feel fat.
Had a great time guys. Unfortunately I I didn't get to meet all of you because I arrived late and only got to race with you guys in the last heat. Then I had to leave right after the third race but it was good to meet Raj and attend my first event (finally). Looking forward to the next one.
  • Like 2
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
