I'm more than happy I went from 43s-40s-38s, even I'm always the last of our group, but I do feel sorry for the kart that has to carry me since I weight 125kg and hey! I break the record of biggest head ever attended to the facility! At first they couldn't find any helmet for me so they ended up taking all the mesh cushion inside a size 3XL out for me to be able to squeeze my head into the helmet, and it's the only 3XL available there.
  • Like 5
says the guy that ate pasta and a spud.
i just noticed i typed 'says'... I meant ask...
I wish, I had a sammich at home... :(
you gotta be there to experience the glorious steak, or you get nothing.
*note, im just over talking the steak to make you jelous. It was OK, not amazing.
Could people please refrain from commenting on todays situation. We as a club would prefer not to have this played out in public.
To be honest, if something occurred and conversations are to be shut down, it looks like the club execs are hiding something. While I've got no idea what happened, as a club member I'd appreciate communication of the basics.
Did someone die?
Did a car get written off doing helis on the grass?
Did someone break a fingernail?
All these things have happened before in the community. Stonewalling makes it look like something terrible needs to be hidden; ask the Catholic Church how that turns out.
Did someone die?
The incident that occurred was relayed to all attendees via PM as will any further updates regarding resolutions and consequences. The main reason we don't want anything being said is we don't need to further inflame the situation. Feel free to PM me or the execs if you'd like
  • Like 1
Yesterday at Luddenham Raceway, there was an altercation between an SAU:NSW Member and staff member at the centre, which due to an unfortunate turn of events has resulted in the member being banned from Luddenham Raceway. The centre is also in talks with SAU about banning all that participated today as well. The acts of one should not affect the many. We ask that people refrain from commenting on the centres Facebook page or on any public forum.
This is being viewed by Luddenham as a club incident and the club executive team is working to mediate the situation between SAU NSW and Luddenham.
Individual members or friends should not correspond about any potential views about this situation here in public forums, Facebook or directly with Luddenham. The executive team is available to discuss the matter with any affected individuals.
We are doing our best to keep those affected by this matter informed. However, while many people will have a view on this matter, we ask that you refrain from any negativity and allow the execs a little time to work through a resolution.
As more information comes to light we will update you on the preceeding. Feel free to contact any SAU:NSW Exec should you have any concerns or questions
  • Like 1
Did someone die?
fingernails are serious business. google image search "broken fingernail",
now back to steak talk...mmm.... steaaaakkkk...
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
