Wantgtr - Now Have One! Bnr32
Engine is in. Nismo mounts and urethane gearbox crossmemmber mounts fitted. Engine feels nice and tight. Whole car moves when you give the motor a push.
'Engine in' was a lot easier than i thought. Gearbox, tailshaft and passenger cv is on. Everything else is left.
Pic for your troubles lol rb25 swap ?
2017-08-16_09-47-46
  • Like 1
9 hours ago, Old man 32 GTR said:
Hey want, just read your thread, what internals did you end up going with and what turbos are you going to run?
No strokers or anything, nitto bits, kelford cams, and eventually single turbo.
starting to put stuff back together slowly. Theres about a million and one little jobs to do, part of it a catch can setup.
This is the stock pcv in the balance tube
20170818_211511
I wont be plumbing the catch can back into the pcv so i replaced it with this
20170818_211848
Much neater than sticking a bolt in a hose. For those playing at home the thread is a 1/4bsp.
  • Like 1
Are you going to go with the Garrett the workshop recommended?
I'd say they 64/66 that's advertised on here is a good buy, might be able to get my hands on a 6boost manifold to suit it as well.
That turbo on a 26 is insane!
The most fun you can have with your pants on!
  • Like 1
  • 5 months later...
Received a package from platnium racing. Definitely a quality piece of gear. Everything packaged really well and fits like a glove. I removed the stock r35 coil stalks and fitted the prp ones. Bracket and loom are mint. Genuine nissan coils supplied eith kit also.
20180221_18350920180221_21271320180221_21272520180221_213218
Kit fits under the cover but i think i might leave it off!!
  • Like 7
  • 3 weeks later...
28 minutes ago, Old man 32 GTR said:
You inspired me want, I just bought the coil kit from Hypertune. I got the black anodised bracket
Niceeee.
Ive been waiting for my ard alternator since december. Pretty frustrating waiting so long but what do you do.
Fuel system is done. 8an feed and return. 1 walbro 460 in the tank, another 2 460s in the raceworks surge. Turbosmart fpr2000, bosch 1650 injectors in an aeroflow rail.
20180204_20555620180203_191236
Primed the surge tank and after a few minutes primed the fuel system. No leaks so very happy about that.
If all goes to plan i should be mere weeks away from firing this thing up. Keen to hear this thing idle and race it.
  • 3 weeks later...
So my Ard alternator finally turned up. That is now in. Same size as the old one so basically in and out job.
In other news. Couple boxes turned up. Had to do a test fit! 6boost with gtx3584rs. Loved the smell of new parts haha
20180329_143318
  • Like 3
Looking tough, what are your plans for the gearbox?
Mines been upgraded to series 3 components but that’s still not strong enough for 500rwkw so it’s all up in the air right now, I want to go a ppg gearset and billet flex plate but all up that’s around 12k.
I’m planing on giving the box a freshen up and putting a twin plate clutch but that’s just temporary.
No plans for the box. When it breaks ill prob just throw another one in or rebuild mine for now. No decent option without spending north of 15k so its not going to upgraded soon.
Going from basically stock to this level was costly.
On 10/03/2018 at 9:32 PM, WantGTR said:
Niceeee.
How do you plan to run the pumps?
Always on or will they be turned on when needed by the ecu, or something different.
    • So next year I am looking at upgrading from my VE SS bomadore ute to something more refined.  I wanted to stick with a V8 but not anything German or Australian, either a coupe or a sedan. So if I wanted anything newish that limited my options to either the Lexus RCF which I quite like. But with the price they demand and a kid on the way a 2 door coupe is probably not going to be the best idea. The next best thing would be the ISF but the newest models are 2014 and commanding over 60k and even the older 2008 models in ok condition starting around 35k is kind of bullshit. So I figured if I could not have the noise I could perhaps make do with easy power. Enter the infinity Q50 or Skyline equivalent. The price difference between the 300 and 400hp models seems a bit crazy. Right now there is 300hp Q50 one on carsales from a dealer with 61km for 27k drive away. If I wanted to get a 400hp Red or 400R car the prices seem to start at 43k From my limited research it seems that the only differences are that the 400r/Red Red runs more boost and a more aggressive tune. There are are turbine speed sensors on the turbos. Has 2 pumps for the water to air intercooler. Runs an engine oil cooler. I'm guessing that the exterior trims might look a little more sporty as well. I had a lazy look for upgrades to bridge the gap on z1motorsports They have kits that upgrade the water to air heat exchanger as well as the coolant pump which should give a non Red/400r better intercooling temps than the stock Red/400r. I added an engine oil cooler with a thermostat as well to try and make things as close as possible. Obviously the ECU is going to need a tickle. Having not done much in the way of research they also sell a ECU flashing tool with pre loaded tunes that are supposed to boost the non Red/400R by 100hp which adds 1k USD to the cost. The total cost of the parts @ the current time including shipping and taxes worked out to be $4350 AUD. Personally I would rather get the car tuned on a dyno which would probably add more cost Assuming the worst that you got a workshop to install the new parts I would guess no more than 5 hours would be required in the worst case @ 5 x $150 per hour = $750 So the total cost could be around $5100 So for easy number 5k + 27K = 32k I guess that would leave some change left over to swap out the open diff and fit a LSD Any thoughts?
    • Right, not sure why I thought it to be a lean spike. It might be fixable with modern card-style hot film MAFs which have some design features to avoid counting reversion flow but I've never tried it myself.
    • I did not realise this, I'll contribute more and earn my stripes and retry later.
    • I'm only going to hassle you for posting links to images. It's against my policy to click links that could be some nasty payload. Sadly, you need to make 9 more posts before you can just stick the images directly in a post, unless @PranK sees this and bends the rule for you.
    • Hello,new to the group, I bought a R32 from auction recently, wondering if anyone knows the cars history, seems to have the usual go fast bits on it, plan is to do an engine swap- add 2 extra cylinders and 1 extra turbo. https://www.dropbox.com/scl/fi/i4rjmlzubjbwjtguh6f4s/IMG20241011140744.jpg?rlkey=q0lumm251377vknbqktfwrycq&st=7scvwx4e&dl=0 https://www.dropbox.com/scl/fi/ro24qmwzlczzlfsr4y05x/Screenshot_2024-10-10-10-49-23-90_9a2f5bb2149dae94cd1e190effc09b33.jpg?rlkey=oyguh26ttshlf04ccp48odf4v&st=xloae97b&dl=0   New to forums and posting pics, if links don't work, take it easy on me, 42yrs old and I tune carburettors!!
