Engine is in. Nismo mounts and urethane gearbox crossmemmber mounts fitted. Engine feels nice and tight. Whole car moves when you give the motor a push.
'Engine in' was a lot easier than i thought. Gearbox, tailshaft and passenger cv is on. Everything else is left.
Pic for your troubles lol rb25 swap ?
2017-08-16_09-47-46
  • Like 1
9 hours ago, Old man 32 GTR said:
Hey want, just read your thread, what internals did you end up going with and what turbos are you going to run?
No strokers or anything, nitto bits, kelford cams, and eventually single turbo.
starting to put stuff back together slowly. Theres about a million and one little jobs to do, part of it a catch can setup.
This is the stock pcv in the balance tube
20170818_211511
I wont be plumbing the catch can back into the pcv so i replaced it with this
20170818_211848
Much neater than sticking a bolt in a hose. For those playing at home the thread is a 1/4bsp.
  • Like 1
Are you going to go with the Garrett the workshop recommended?
I'd say they 64/66 that's advertised on here is a good buy, might be able to get my hands on a 6boost manifold to suit it as well.
That turbo on a 26 is insane!
The most fun you can have with your pants on!
  • Like 1
  • 5 months later...
Received a package from platnium racing. Definitely a quality piece of gear. Everything packaged really well and fits like a glove. I removed the stock r35 coil stalks and fitted the prp ones. Bracket and loom are mint. Genuine nissan coils supplied eith kit also.
20180221_18350920180221_21271320180221_21272520180221_213218
Kit fits under the cover but i think i might leave it off!!
  • Like 7
  • 3 weeks later...
28 minutes ago, Old man 32 GTR said:
You inspired me want, I just bought the coil kit from Hypertune. I got the black anodised bracket
Niceeee.
Ive been waiting for my ard alternator since december. Pretty frustrating waiting so long but what do you do.
Fuel system is done. 8an feed and return. 1 walbro 460 in the tank, another 2 460s in the raceworks surge. Turbosmart fpr2000, bosch 1650 injectors in an aeroflow rail.
20180204_20555620180203_191236
Primed the surge tank and after a few minutes primed the fuel system. No leaks so very happy about that.
If all goes to plan i should be mere weeks away from firing this thing up. Keen to hear this thing idle and race it.
  • 3 weeks later...
So my Ard alternator finally turned up. That is now in. Same size as the old one so basically in and out job.
In other news. Couple boxes turned up. Had to do a test fit! 6boost with gtx3584rs. Loved the smell of new parts haha
20180329_143318
  • Like 3
Looking tough, what are your plans for the gearbox?
Mines been upgraded to series 3 components but that’s still not strong enough for 500rwkw so it’s all up in the air right now, I want to go a ppg gearset and billet flex plate but all up that’s around 12k.
I’m planing on giving the box a freshen up and putting a twin plate clutch but that’s just temporary.
No plans for the box. When it breaks ill prob just throw another one in or rebuild mine for now. No decent option without spending north of 15k so its not going to upgraded soon.
Going from basically stock to this level was costly.
Single, sexy :)
Curious to see what you'll make/do with the 2.6L and static cam - I might get bored one day (when the car is finished and running properly) and upgrade to a GTX3584RS too to be like you.
On 10/03/2018 at 9:32 PM, WantGTR said:
Niceeee.
How do you plan to run the pumps?
Always on or will they be turned on when needed by the ecu, or something different.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
