9 hours ago, Dose Pipe Sutututu said:
Like a boss!
Going to run a fuel cooler? Fuel might get a bit warm with those heaters haha
I want to get the car running and tuned. I know there will be gremlins to sort out so will take it as comes. Car goes in for fab work later this week. Some ceramic coating to follow then fire dis bish up. Cant wait to hear dat bridgeport idle.
So i spent some time tonight moving the now largely useless loom from the passenger side engine bay into the gaurd.
This connector was part of it. Does anyone know what it does? Does it need to be plugged in?
2018-04-14_11-18-41
Seems to lead to the wheel hub. Is it an abs or awd thing?
I looked this up at one point on my own car and yes I'm fairly sure it was the abs sensor
Yeah i think so also. Have extended the loom on the sensor and connected it up where it needs to go. All good, was lazy for a second lol
  • 3 weeks later...
2 hours ago, Old man 32 GTR said:
How are you travelling with the build, can’t be much left now?
Mechanical work is done. Fab work done recently by a friend. Work was top notch. Custom baffled catch can and battery mount, bracket for power steering reservoir, intake pipe and dump pipe with vbands, gate pipe welded up etc
2018-05-01_08-23-41
Got the manifold, dump, rear housing, gate pipe ceramic coated.
After i got everything back i got busy at home. Braided oil and water lines, braided wastegate hoses, moved wiring into the gaurd, sorted out power steering hoses.
A while back i wired up the io box with flex, oil press, fuel press, boost solenoid, map sensor, wb1 controller kit so thats all sorted.
Cranked it over last night. engine eventually started for a few seconds before the wife came in and was forced to shut it down. Guess i shouldny really be starting it at 10pm with the newborn sleeping diredtly above the garage!
After i actually get it idling ill send it in for tuning. Not long now.
2018-05-01_08-21-06
Sounded beastly. I forgot how much i miss it.
  • Like 6
1 hour ago, Old man 32 GTR said:
Awesome result, what boost are you pushing through it?
You’re going to have your hands full when it’s on boost
Thats on 32psi only. Can push it further but need a heavier wastegate spring.
  • 1 month later...
So managed to get 1 run in at wsid before they cancelled the night got cancelled. 10.8 @ 140mph.
Will try and get back out there and better the time. Launch was messy at 1.8 60ft.
2018-07-05_07-22-442018-07-05_07-22-17
Overall ecstatic. 10s first pass. No prep. Decided i was going to race at 6pm after i finished work. Didnt even check tyre pressures or oil level. Opened the garage and drove to the track. With 140mph, theres heaps of room to improve the time.
  • Like 3
  • 7 months later...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
