Hi guys.
I'm wanting to replace the clutch in my V as it's beginning to slip and i'd hate for the unthinkable to happen and leave me stranded. Looking to replace with Exedy factory option as i'm not needing anything too heavy duty, naturally looking to source the item as cheaply as possible.
Does anybody know the difference between the Exedy NSK-7422DMF (Australian Market) and Exedy NSK1000FW (US Market)? I'm guessing only the part number given the Nissan and Infiniti coupes are the same car.
https://www.sau.com.au/forums/topic/456361-clutch-replacement/
Great, thanks mate.
After doing a bit of research and having a lengthy chat with my mechanic, I've decided to do the single mass flywheel conversion using Exedy NSK-7454SMF. Are any vendors able to supply this? I've tried the search function but it doesn't seem to be working this morning :closedeyes:
Edited by TUFF_350
let us know how you go with it. when I did my clutch replacement I went with a new DMF as I was scared off by the SMF guys complaining about low RPM gearbox chatter and I didn't want that in my daily..
I ordered my DMF and Exedy clutch kit from USA, ended up just under $1k. Not sure who stocks these locally, but they will be the same as the 350Z..
from here -
http://www.ebay.com.au/itm/EXEDY-CLUTCH-KIT-LUK-DMF-03-06-NISSAN-350Z-03-07-INFINITI-G35-3-5L-V6-VQ35DE-/251932446372
But the exchange rate is going to kill you. I bought mine over a year ago when it was still around A$1.10 to US$1.00
And because the figure will now be over A$1, import duty will kick in!
Edited by sonicii
Well i bit the bullet and just bought this:
http://www.ebay.com.au/itm/EXEDY-CLUTCH-SINGLE-MASS-FLYWHEEL-CONVERSION-NISSAN-SKYLINE-350GT-V35-02-07-/161691050017?pt=LH_DefaultDomain_15&hash=item25a589a021
Awesome price, getting it installed locally next Friday. Once it settles in i'll let everyone know how it goes as far as gearbox chatter etc under 1,500rpm.
I know this doesn't help you much since you have already bought the above kit.. but this popped up on ebay the other day.
http://www.ebay.com.au/itm/Exedy-Nissan-350Z-Dual-Mass-Flywheel-Clutch-Kit-NSK7422DMF-/191578489552?pt=LH_DefaultDomain_15&hash=item2c9af7c2d0
Fully installed and wow what a difference, the car feels brand new and drive-ability is second to none!
Slight chatter below 1,500 rpm is definite, but it's certainly not annoying or off putting in anyway :no:
Also if anyone is interested:
http://www.carsales.com.au/private/details/Nissan-Skyline-2005/SSE-AD-2619110/?Cr=1
I had mine replaced dec 2014 by C-red. They installed the SMF option and the chatter is quite noticeable. With the reduction in rotating mass I have noticed little improvement on acceleration. In-fact the car feels quite the opposite, almost like there is drag in the driveline.
If you ride the clutch in a certain position the car shudders. I'm sure my off-the-line acceleration was better with the stock clutch (prior to wear).
Im surprised to hear that from your first hand experience. Keen on replacing my dmf to a smf, or more importantantly a lightened flywheel, as there has to be a better result.
Everyother car that I have replaced the clutch on, I have gone a lightened flywheel with great results.
mosoto did your kit come with a lightened flywheel?
Yes, iirc they only had the SMF with lightened flywheel option available from their supplier. I must add that the exhaust note has changed which may be coincidence, It's deeper and louder which is a good thing :)
  • 7 years later...
After 186k, slipping clutch( occasional sticking pedal from 160k) I finally changed my clutch to ACS Extreme HD Single Mass. Only driven today but, can say:-
1. no noise diff or chatter at idle (if anything prob less chatter)
2. Occasional light clutter noise on first release. Not always
3.Occasionally light low speed lash, noise, through drivetrain whilst upshifting in corners.(again not always maybe different revs gear change)
4. Slightly quicker (maybe .05/s more responsive upshifts). Generally crisper feel.
5. In gear acceleration from lower revs a bit better.
6. Slightly different noise through the transmission during gear changes both up / down. Not more or less just different.
7. you can service this flywheel/ replace clutch plate - You cannot do this on Dual mass OEM flywheel -such a shame for $2.5k unit. Good HD Single mass is still over 2.1k fitted but many suppliers are quoting the same for both HD’s. Some more for dual.
I only went this way as I think it would improve response on an old engine with a slightly lighter flywheel & so far it feels that way. My car still has a great deal of torque with the exhaust and chip on the timing & having a solid flywheel feels right for it.
Its obviously too early to get a full judgement. So hopefully I’m not spewing in a years time.But the Heavy duty flywheel SM is not too much lighter than the dual and my understanding is the new clutch plate on the SM has more spring & material for dampening to compensate for the lighter solid mass.          (not fully obviously).
Hopefully this helps. Will keep you posted if things change.
cheers
Elie
Nice, good to hear it went well. my DMF has also been fine for the last 8 years.  From what i have heard the heavier SMFs experience less of the chatter issues.
Just one point.  The claim that a DMF can't be resurfaced is a myth, you just need a workshop with the right tools to lock the 2 sections of the DMF together to allow it to be machined.
Hi sonicii, yes thats what I thought and even my brother who’s a fitter just said today anything can be machined.so I’ll edit my pt7.
I’m still familiarising myself with it and must confess its a little odd getting the tiny “knock” sounds randomly, mostly cornering.
UPDATE: The little knocking was the Engine Mounts!. Got No idea why one engine mount was nearly all the way loose! & other half way!!.  Mechanic said he “did not touch them”. Bit of lock tight & tension & bobs your uncle!.
The car now drives with no noises what so ever & smooth as .( other than slight CV/suspension creek that was there before). Very little to no chatter -same or less than original clutch -but as I said above its very early. This clutch holds speed (coasts) well under 60 and the original DM better above 80. You have to adjust driving with lighter throttle on SM & holding it longer on highway speeds.
Mine was done at Oyaji Motorsports & I would  NOT recommend them to anyone ATM. Maurice is in Japan & only have fabricator doing ALL mechanic work, the very little time they are open. I did not know any of this when Maurice quoted!. me. If he’d told me any of this No Way would I have gone there.
They f/d up bleeding the system taking a whole day & half!!. When I told them where the problem must be & was! The bolt below the master was not done up properly! (On them). Then they brushed me twice - saying you need to get familiar with new clutch for weeks /month . Luckily only the second week in I told them something is seriously going wrong & literally had to get the installer in the car again after 10min on the hoist all became obvious!!!..
  • Like 1
    • The R32 suffers from an instrument binnacle that is uncomfortably close to the design of a VN Commodore's. But beyond that, the layout of the rest of everything, and the materials (ie the vinyl coverings on dash, armrest, etc) are acceptable, and the patterns on the fabrics are not as blergh as those in the R33. And R33 seats are....quite unattractive. I know it's only small details there, but I reckon the R33 got worse than the 32. But the big blergh is the overall shape of the dash on the R33. It's just has that whole Maxima/Pulsar sort of look to it. Nothing special at all. Generic Nissan sedan. Whereas, at least the R32 dash/binnacle was different. Less a wide expanse of boringly curved plastic. More a "cockpit" sort of look, even if nowhere near to the degree that the A90 Supras got. R34 seats look good on their own, until you realise that they are indistinguishable from the shape and fabric on 70 other Japanese cars. And the foam bolsters on them suffer even worse than the earlier cars. Other than that I don't really have an opinion the rest of the R34 interior. I took the bits of the R34 I wanted (brakes and engine) and added them to the best external appearance Skyline in the modern era (the 32). So nyerr!
    • Can I be your first customer? I would like hard lines done for the fuel system, 8AN up and 8AN back and the underside wire wheeled and coated (brush or sprayed) with that black tar shit.
    • Speak for yourself, I love the R33 interior. 32 is blergh. I like the 34 interior too. Then you start getting much newer in most cars and they all turn back to blergh. 😛
    • 500-600hp into a RB is already 'sinking endless amounts of money' into an engine. Especially a 30 year old engine. Unfortunately this is the RB Game. Considering stock power (or at least stock components) will do ~360whp on 98 by simply turning up the boost on the stock gear on a RB26, that would be where I'd say the cutoff point for "sinking endless amounts of money into the engine" Cause to even do this reliably you'd probably need to replace all the bits anyway cause they're old, starting your sinking journey anyway. I reckon the least painful way is rebuilding the engine to make 50hp over stock lol. The 'plan your ownership around a rebuild' was a common saying 15 years ago.
    • Well, the NA RB25 is nothing special in terms of the amount of power it makes stock, nor with any easy mods like extractors & exhaust, opening up the intake tract, etc, etc. And just like any small capacity NA engine, getting lots of power out of them takes a fair bit of money and, depending on how far you go with big cams and high compression and so on, quite grumpy to drive. So, boost is the answer. Many many many of them have had a turbo added. This is easy enough. Same as for any engine. Need the things you need to bolt on the turbo of choice, fuel system and management upgrades, clutch, stronger gearbox ( you do not want to run a boost RB25 through the NA box), diff, brakes, etc, etc, same as you would for most other NA+T things. Some much smaller number have had a supercharger added instead. These are good and cool, but have nowhere near the potential of the turbo route. All the same required upgrades apply. So, potential? Anywhere from not much to quite a lot, depending on how much effort and expense you want to go to. Is there value in the effort and expense? Objectively, no, there is not. If you're gaining enjoyment and don't mind blowing a lot of money on the project, then that's where the value is. Parts? Nissan dealers for some. Many many on-line vendors who do Japanese manufacturer spares (buy buying them from disposals at dealers around the world, direct from manufacturers, increasingly from Chinese knockoffs, etc) and warehousing them in Dubai or similar places. Amayama, Partsouk, etc etc. There are quite a few. Some local to Australia, some local to Europe, some local to the US. You can upgrade literally everything. For an NA, unless you're going to boost it, there's little point going past a nice exhaust, as I said above. After that (well, actually probably even before that) you should concentrate on making it handle the best it can, good brake components, light wheels and tyres, and just make it something to enjoy throwing through the curves. You'll never, ever win any drag races, so it needs to be taken as a nice point-to-point car. Throw in some Recaros or Brides, nice Momo wheel and gearknob, so it's pleasant to be in (because god knows, the inside of an R33 is not a pretty place!!) and away you go.
