I didn't have any issues with cam timing when fitting the belt. All the marks lined up but I'm not convinced timing will be 100%; that's where adjustable gears come in handy.
I installed the 1000cc bosch injectors I bought from Kinkstahh who was kind enough to get scotty to knock up some plugs that will go straight into the factory injector loom.
I'm using the factory rail and reg as there isn't much point in going aftermarket. I gave it a lick of paint though as it was looking pretty rough. Bunnings high temp black FTW
I'm not sure who to get to tune it. I will need a dump pipe made up and possibly a pipe from the RH guard to the plenum.
I'm tempted to either tow it somewhere like JEM where they can finish it off for me and do the run in tune. Any ideas there?
edit: not sure why the pictures came out sideways
Edited by Blackkers
Thanks for the tip luke I'll be sure to do that.
I can't wait either!
I'm putting the intake back together currently. Cleaning the throttles and scraping gaskets has taken hours today.
remembering where all the vac and coolant hoses go is a nightmare as well!!
Be careful with those throttles as you can remove the seal and cause more leaks. The intake side is never fun when putting back together.
I've seen some good work come out of JEM and they seem to be able to do it fairly quickly which is a bonus. Maybe give them a ring if you are inclined to go to them and see what they can do for you.
Looking forwards to the results from this build.
What's the issue? I just used degreaser on the throttles and scraped off the old baked on paper gaskets.
Should I reassemble with a bit of sealant? I was going to leave it dry but now you have me worried
I poured some Kerosene in the throttles to leave it for a while and see if they leaked. Well sure enough all of them leaked almost immediately. I don't know whether to worry about this or not.
After using some gasket remover on the plenum some of the paint started peeling. I ended up painting that too although it doesn't look much better than before!
starting to look like an engine
Personally to minimize the risk of it all going bad, id clean them right up and reseal them or grab a set you know haven't been cleaned/messed with and fit them.
I had to clean some throttles up today for a plenum I have off a car and just used a razor blade to peel the gaskets off
You can buy the Tomei sealant and reseal it all properly if you want to be sure. Otherwise you will find out when you have a high idle after putting the motor in the car and you'll be up for more work.
There is a guide/thread about it all on here as people think to clean them out while its off but ends up causing more drama.
That guide was written by me, pictures are long gone (dont know what happened there) but it fixed it and its still working fine today (years later)
Dont be afraid if you do clean off the coating, its no big deal to fix, more a frustration hoping you get it right as you cant test it till its all back together again.
Hey guys back again.
This week I'm going to have some AN fittings welded onto the sump before I remove the diff and have it all cleaned up.
Fittings I'm using:
2x -10 AN
1x -12 AN
The first -10 will go as a breather to the rear of the head
the second -10 will go to the bottom of the Catch can as a drain back to the sump.
The -12 will go as a breather to the top of the catch can
The head will have a -10 rear breather to sump
2x -12 push on fittings for the cam breathers connected to the catch can as well
The catch can I'm tempted to use will be the Hi Octane direct with 3x -12 breathers (1 sump, 2 cam covers). and a -10 drain (sump).
A breather will be connected to the vacuum from the turbo inlet
I know that's confusing so I drew a (also confusing) diagram:
Does anyone see anything wrong with this? The hi octane catch can will need to be modified for the extra -12 breather if they can't do it in house (http://www.hioctanedirect.com/index.php?main_page=product_info&cPath=67_74&products_id=1448)
Thanks
I guess I should mention I'm using 1.25mm and blank oil plugs in the block with an R34det neo oil pump that's been overhauled.
Standard sump size and RIPS pickup/awd adaptor with tomei baffles. The engine is unlikely to break 7500rpm
Considering I already have the rear fitting tapped and installed and I have not opened up where the oil drains back down the block I'm just going to do it anyway as it's easy.
Also I have 2 - 12 breathers from the head and only one - 12 from the sump so it will help equalise pressure without interrupting oil return.
You're probably right it's not needed but I'm set up for it
Couple of mock up glory shots.
Massive exhaust wheel (approx 62-63mm) in the tiny .63 T3 rear housing.
ATR45SAT should make a responsive 400-420rwkw. I'll probably run it around 22-24 psi. I hope a Walbro 460 and 1000cc EV14's on the stock rail/reg can keep up
I'm waiting on fittings to arrive then I can put the sump together.
Catch can should be ready next week. I might get it powdercoated in black
  • 1 year later...
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
