Hey, anyone have experience with using this little gadget on a V36.
http://www.ebay.com.au/itm/201031617244?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
The GTR Guys use them for track days to avoid a bonnet pop from hitting a cone etc.
The connector looks exactly the same on the V36, I guess its probably just some sort of resistor.
I've emailed the seller in Japan & he could not say whether or not it would work with the V36, just that they have not tested it with one.
Has anyone here tested/using this on a V36 for track days etc?
Cheers.
https://www.sau.com.au/forums/topic/456412-bonnet-pop-up-cancellers/
Best way to be sure would be to put an oscilloscope to one of the pins to see what voltages you see. If it's constant, then you're right, it's likely to be a purely resistive load. But if you see a pulse train of some sort, then chances are there's more to it than just a resistor, particularly if there's more than just two pins to the connector.
Ok, after a bit more research, I've spoken to a guy in Japan who helps me occasionally bring in Vintage Japanese Electric Guitars which I am a collector of.
He says, in Japan they make this for R35 GTR, V36, Y51 & Z34, one part fits all.
So as a bit of a favor he's going to source a set locally & send to me.
So, I guess I'll be the Guinea Pig. Does sound pretty positive though.
Cheers.
Sure, probably going to be 2/3 weeks before I get the parts & then probably another week to find time to do the job.
I'll do a pictorial "how to" if successful, for anyone that might want to do it also.
So unfortunately it could be a Month at the outside for a definitive conclusion.
So, bear with me if I don't update the thread for a little while,
Cheers.
Doing a 'how to' would be great, but I would be careful what you mention on a public forum.
Permanently canceling a pedestrian safety feature would be frowned upon by the authorities and your insurance in the case of an accident, especially if a pedestrian was hurt. You may end up paying any compensation yourself, even if it was their stupid fault.
Hi Scott, yes I fully understand that. I consider it a track only mod.
From what I gather its quickly reversible by just unplugging the modules & re-plugging in the Bonnet poppers (battery disconnected of course, thanks Ben.).
The "how to" is just to show people what they need to remove etc to get access to the connectors.
I certainly understand where your coming from though.
Cheers.
Edited by mycarhasposessedme
  • 3 weeks later...
Okay, good news.
They Fit & work 100%.
I ended up buying a set off Ebay to suit R35 GTR, as my mate in Japan let me down unfortunately.
Access to the connectors is pretty tricky but totally do-able.
With both Bonnet Poppers disconnected & the Cancellers installed there are no check lights on the Dash.
I've done around 1500k's with them now, Track only of course & no probs.
I'll post up some pics later.
Cheers.
  • Like 1
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
